5th wheel hitch - Page 2 - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 10Likes
post #11 of 33 Old 04-30-2019, 02:03 PM
jetjock15's Avatar
Quoted: 342 Post(s)
Ok wow I was researching the Anderson today and there is numerous, literally many instances of failure. Never heard of such high failure rate. I tow very heavy trailers so no more Anderson consideration for me. Look on Amazon and filter reviews by 1 star for many documented failures. Google for Many more. I will not recommend anymore. A 35lb hitch, was too good to be true
https://www.amazon.com/gp/aw/reviews...r&pageNumber=1
JustinOOO9 and joebuck like this.
19 F450
I’ve owned previous vehicles but I won’t waste the forum space to list them, oh ya, and you don’t care
jetjock15 is offline
post #12 of 33 Old 04-30-2019, 02:16 PM Thread Starter
Quoted: 3 Post(s)
Just looked at their site to see how it works. Not sure I want to go that route even though it is the lightest out there. I like the idea of my 10,000 lb 5th wheel with my boat in tow to be anchored to a real 5th wheel hitch in my bed. There is a reason 5th wheel hitches are connected using 4 points and not just 1 like a gooseneck.
Must say it is an interesting setup but not for me. Thinking of going with a Curt A24. Seems to be best bang for the dollar.
Sent from my iPad using Tapatalk
Leclerc457 is offline
post #13 of 33 Old 04-30-2019, 03:45 PM
Sock Puppet's Avatar
Quoted: 575 Post(s)
The Anderson drops into the gooseneck ball right? All trucks with pucks have the ball too I think
I think they offer a couple of options, but I haven't kept up. Mine attaches to a gooseneck ball and works great. I had the original version back in 2013 or so and liked it, but the newer/lighter model is awesome.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #14 of 33 Old 04-30-2019, 05:05 PM
Quoted: 27 Post(s)
Anderson also makes a gooseneck attachment that attaches to your trailer and then you can use your gooseneck. This is the route i'll be going.
Warboar is offline
post #15 of 33 Old 04-30-2019, 07:19 PM
cletusjermal's Avatar
Quoted: 406 Post(s)
I have the anderson and like it. Mine is the one that attaches to the GN ball. They also have one that hooks to the rails if you have bed rails.
2017 F350 6.7L 4x4 FX4 SRW CCSB Lariat Ultimate
Sold—2002 F350 7.3 4x4 SRW CCLB. GTP38R, PIS 175/80 injectors, Sam Wyse Stage 2 Trans, 6.0 cooler, Banks Intercooler, 4" Turbo back Exhaust, PHP tuned TS 6 position chip, CNC 4 Line feed, HPOP and HPX Lines. International bellowed up pipes. AFE Stage 2 Intake w/ Dry filter. Banks exhaust brake and smart lock. Hutch/Harpoon mod, 910 Valve springs, Billet intake plenums. Firestone airbags. Trailready full guard front bumper. PIAA Driving and Fog lights. Micky Thompson Wheels.
cletusjermal is offline
post #16 of 33 Old 05-01-2019, 03:32 PM
Love my Reese 20K that I bought from etrailer when Reese was having a discount last year
6.7Ezlynk is offline
post #17 of 33 Old 05-02-2019, 05:36 AM
joebuck's Avatar
Quoted: 155 Post(s)
Ya I’ve heard more bad than good with those things which is why I didn’t go that route when we picked up our 5er, for the let’s call it 20 times a year I take my set up in and out of my truck it’s worth it to have a beefier set up, one I know won’t buckle under a load. Especially at the weight your pulling @jetjock15 that would be some crazy stress on aluminum I wouldn’t be comfortable hauling with it.
2012 F350 CCLB Lariat/ EZ Lynk Tyrant tuned/deleted/15+turbo swap/No limit stage 2 intake/H&S silicone CAC pipe/5” exhaust/2.5” BDS Leveling kit on 35s/Fox shocks/20” XD grenades
joebuck is offline
post #18 of 33 Old 05-02-2019, 07:01 AM
jetjock15's Avatar
Quoted: 342 Post(s)
I do want an easier to manage setup, Assuming one exists. My Reese is like 300 lbs. I keep considering gooseneck but I have towed gooseneck trailers about 5 times, with three different trucks and trailer combos and they all “bucked” fierce in a way a fifth wheel never does. I always am hesitant because every mainstream RV is made fifth wheel, not gooseneck and every semi used a fifth wheel connection not gooseneck so that tells me something.
I’ve heard bad things about the stress load of adapters so I’d go with a pin box replace and the Geny cushioned coupler. Still considering
The geny, in hopes eliminate buck
https://www.summitracing.com/parts/g...xoC6NQQAvD_BwE
The replacement pin box
https://www.amazon.com/Pop-Up-RVGC43...29954477&psc=1
post #19 of 33 Old 05-02-2019, 07:08 AM
Other option is something like a reese goosebox if you use your bed frequently. I just swapped from an anderson to the goosebox and it rides great with the airbag and shocks that are built into the goosebox, and it is approved by lippert for use on their frames (because lippert owns reese). All other gooseneck conversions could potentially void the rv frame warranty.
wakeboarder2186 is offline
post #20 of 33 Old 05-02-2019, 07:22 AM
Quoted: 27 Post(s)
https://www.reesehitches.com/product...BoCn5wQAvD_BwE
They’re pretty proud of them.
This is the route I was looking at going.
https://www.etrailer.com/Gooseneck-a...l/CAB-C5G.html
Sent from my iPhone using Tapatalk
Warboar is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wheel Width, Backspacing and Offset on 2.5"-4.5" Lifts OCVeloMan Wheels, Tires, and Brakes 19 04-03-2018 04:35 PM
Fifth Wheel Hitch. Puck vs ball ??? fordtester General 6.7 Discussion (2017-2019) 14 10-24-2017 02:51 PM
