Left tire rubbing on bumper when turning right - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 7Likes
post #1 of 18 Old 04-18-2019, 02:45 PM Thread Starter
Quoted: 8 Post(s)
BUMPER not fender.
Right tire is fine both ways, left tire hits bottom corner of bumper when turning right. Just lifted it Sunday and put wheels/tires on. After looking closer and measuring, the bumper is almost 2 inches closer to the left tire than the right tire. Never hit anything and bought it new. Any ideas why or best way to fix it?
rrambo is offline
post #2 of 18 Old 04-18-2019, 05:01 PM
jetjock15's Avatar
Quoted: 286 Post(s)
Why? Ya cause your lift and tires. Fix? Trac bar is what centers an axle. If it’s not centered than that’s your culprit. Your “kit” should of included parts to correct. Once centered, if it rubs it’s because of wheel width and offset. The fix, assuming new wheels not an option, is cutting away the plastic inside fender wheels
Heavy_GD and Warboar like this.
19 F450. Hauls my toys. Dumont regular
Build thread:
Truck pics on IG @ Jetjock15
Iíve owned previous vehicles but I wonít waste the forum space to list them, oh ya, and you donít care
jetjock15 is offline
The Following User Says Thank You to jetjock15 For This Useful Post:
Heavy_GD (04-23-2019)
post #3 of 18 Old 04-18-2019, 05:34 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 558 Post(s)
Feedback Score: 11 reviews
What kit?
Sounds like your trac bar wasn't relocated or replaced.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #4 of 18 Old 04-20-2019, 06:29 AM Thread Starter
Quoted: 8 Post(s)
Left tire rubbing on BUMPER when turning right
So apparently my brain was disconnected from my typing fingers. Not rubbing the fender. The BUMPER. Trac bar relocation bracket was installed and axle is centered left to right. The BUMPER is closer to the tire from front to back on the driver side with the tires pointing straight.
It's like you hit something head on with the bumper on the driver's side. Only I haven't. You can't really tell without actually measuring it.
Since the BUMPER is closer to the tire it rubs when turning right.
rrambo is offline
post #5 of 18 Old 04-20-2019, 07:42 AM
jetjock15's Avatar
Quoted: 286 Post(s)
Stock bumper or aftermarket. God you make us pull information. Did you get aftermarket radius arms or 4 link? Are they adjustable, like threaded heims? So you axle is not straight or it’s your bumper. I’d want to figure that out. All else being equal you couod use spacers (washers) to space out the bumper on one side but that’s a duct tape style fix. You got issues but with no pics or description it’s a needle in a haystack. Try Archoil, Many a fools on here claim it fixes everything, literally everything. Might try
rabpearson likes this.
Build thread:
post #6 of 18 Old 04-20-2019, 08:10 AM
Fishsizzle's Avatar
Quoted: 129 Post(s)
Garage
www.powerstrokehelp.com
2017 F250 CrewCab Short, leveled with 35/12.5/20 Toyo MT. Fuel 20x10
TOTALED: 2010 F-350 6.4 Crew-Short, Sinister Deletes, Coolant Filter. SCT with Tunes. CTS2 monitor, Mishi Rad, CFS Intercooler. Cold Side pipe, Down Pipe. 2.5 level, 295/65/20 Kenwood 9900 Apple Car Play
Fishsizzle is offline
post #7 of 18 Old 04-20-2019, 11:41 AM Thread Starter
Quoted: 8 Post(s)
Sorry guys for not being clear. It's all a stock bumper problem, nothing else. Axle is straight and centered. The whole problem is the bumper.
rrambo is offline
post #8 of 18 Old 04-21-2019, 05:45 AM
Quoted: 2 Post(s)
I bet your bumper isn't closer, I bet your axel is pushed forward on one side. Are your radius arms adjustable kind?
Movesfast is offline
post #9 of 18 Old 04-21-2019, 08:39 AM
G8orFord's Avatar
Quoted: 2433 Post(s)
Garage
Measure from rear tire to front on both sides to confirm the axle is straight.
john galt and Movesfast like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #10 of 18 Old 04-21-2019, 03:11 PM
Alberta Advantage's Avatar
Quoted: 40 Post(s)
KD Fabworks makes bumper spacers that will push the bumper out 3/4”. Not sure if that’s enough room for clearance in your application or not.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Left front brake rotor, rubbing against caliper cage Rdizzle Wheels, Tires, and Brakes 14 09-29-2017 03:40 PM
Binding noise from Right front when turning left tinpusher1 General 6.0L Discussion 15 09-22-2017 06:39 PM
Problems with Road Armor Bumper Bigandy23 General 6.0L Discussion 32 03-24-2017 05:59 AM
Speaker wire polarity diagram midget 6.7 Electronics Discussion (2011-2016) 5 03-17-2017 01:35 AM
BDP half kit and winch bumper? wellsit 6.4L Performance Parts Discussion 5 11-01-2016 08:25 AM
