2019 Coolant Temperature Gauge (and warm up) - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 3Likes
post #1 of 11 Old 12-29-2018, 09:41 PM Thread Starter
Quoted: 6 Post(s)
So my F-250 coolant temperature gauge is off-scale and does not register any "blue" until driven a few miles on cool mornings. All other temp gauges point to a blue notch at the lower end of the scale upon startup. Anyone else seeing this behavior?
No biggie - I totally love the truck and can live with this or see if there is a software upgrade at first service.
2019 F-250 Lariat
Last edited by JSolve; 01-01-2019 at 06:49 PM. Reason: Enhanced title per discussion)
JSolve is offline
post #2 of 11 Old 12-29-2018, 11:28 PM
Fishsizzle's Avatar
Quoted: 153 Post(s)
Garage
I’ll have to look, but honestly I look at the CTS2 monitor all the time not guages. Maybe I’ll be able to see both to let ya know
HeavyAssault and JSolve like this.
2017 F250 CrewCab Short, leveled with 35/12.5/20 Toyo MT. Fuel 20x10
TOTALED: 2010 F-350 6.4 Crew-Short, Sinister Deletes, Coolant Filter. SCT with Tunes. CTS2 monitor, Mishi Rad, CFS Intercooler. Cold Side pipe, Down Pipe. 2.5 level, 295/65/20 Kenwood 9900 Apple Car Play
Fishsizzle is offline
The Following User Says Thank You to Fishsizzle For This Useful Post:
JSolve (12-30-2018)
post #3 of 11 Old 12-31-2018, 03:54 AM
Quoted: 5 Post(s)
Yep it's a normal behavior, I think it doesn't register anything below a certain temp. However I can't say exactly what that temp would be.
areuriding is offline
The Following 2 Users Say Thank You to areuriding For This Useful Post:
JSolve (12-31-2018)
post #4 of 11 Old 01-01-2019, 12:05 AM
Magnetic6.7's Avatar
Quoted: 3 Post(s)
Garage
My 2018 behaves the same way as well.
2018 "Magnetic" F-250 FX4 6.7 Diesel
Magnetic6.7 is offline
post #5 of 11 Old 01-01-2019, 06:01 AM
G8orFord's Avatar
Quoted: 2605 Post(s)
Garage
You can add the digital temp readout above the gauge with Forscan.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #6 of 11 Old 01-01-2019, 08:34 AM
jetjock15's Avatar
Quoted: 351 Post(s)
I’m not sure your question, the reason it doesn’t read min temp on startup is because it’s not at min temp. So your driving it outside of the recommended temp window, likely causing significant premature wear. What you need to do is let it warm up. Let it register min acceptable temp before you drive it. Still confused by the question. If you want to get 300k + out of that motor (or any motor) let it warm up. Best to let oil temp get above 180 as a golden rule but as a minimum let your coolant temp get there before putting demand on the engine. Different metal expand at different rates, a cold engine should be let get warn before you load it up
19 F450
Iíve owned previous vehicles but I wonít waste the forum space to list them, oh ya, and you donít care
jetjock15 is offline
post #7 of 11 Old 01-01-2019, 05:39 PM Thread Starter
Quoted: 6 Post(s)
Originally Posted by jetjock15 View Post
Iím not sure your question, the reason it doesnít read min temp on startup is because itís not at min temp. So your driving it outside of the recommended temp window, likely causing significant premature wear. What you need to do is let it warm up. Let it register min acceptable temp before you drive it. Still confused by the question. If you want to get 300k + out of that motor (or any motor) let it warm up. Best to let oil temp get above 180 as a golden rule but as a minimum let your coolant temp get there before putting demand on the engine. Different metal expand at different rates, a cold engine should be let get warn before you load it up
Thank you JetJock; Point well taken, at least under load. Otherwise I have been letting the fluids circulate for a minute or so before driving. I live where the temp rarely drops below 50 and my initial few miles are always on flat roads and under 40 mph. I've read in other threads how these new diesels hate idling and how the best way to warm them up is by gentle driving.
Other thoughts anyone?
2019 F-250 Lariat
JSolve is offline
The Following User Says Thank You to JSolve For This Useful Post:
jetjock15 (01-01-2019)
post #8 of 11 Old 01-01-2019, 06:14 PM
Quoted: 30 Post(s)
That's how I do it. Idling long enough to let a diesel come to operating temperature is a waste of time and money to me. I hit the remote start as I'm walking up to the truck. By the time I've buckled in and have the key turned in the ignition I'm ready to pull out. YMMV
2019 Silver Spruce Lariat CCLB SRW F-350 FX4
Sport45 is offline
post #9 of 11 Old 01-01-2019, 08:38 PM
jetjock15's Avatar
Quoted: 351 Post(s)
I’m old school I guess and no changing that now. I let mine idle a good 15 min before it moves. But I normally towing heavy too, so less opportunity to let it warn itself up.
19 F450
post #10 of 11 Old 01-01-2019, 09:12 PM Thread Starter
Quoted: 6 Post(s)
Iím old school I guess and no changing that now. I let mine idle a good 15 min before it moves. But I normally towing heavy too, so less opportunity to let it warn itself up.
Thanks JetJock. When towing I will remember to do exactly that.
2019 F-250 Lariat
JSolve is offline
