Where do you get your oil changed? - Page 2 - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 1Likes
post #11 of 12 Old 10-23-2018, 06:24 PM
Rocweiller's Avatar
Quoted: 66 Post(s)
Originally Posted by Painted Horse View Post
My Ford Dealer does "The Works" for $110 That's oil change, tire rotation etc.
Of course they pull all the filters and come show me how dirty my air filter is and say I should change it etc.
Every 5th oil change is free.
So I use them when I don't want to change it myself. Usually when it's wet or snowy out.
When I have time I use a 5 gallon bucket and drill a hole in the filter and let it drain. Remove it and move over to the oil pan drain and remove it.
Beware it really shoots out of the drain plug. Carefully position your 5-gallon bucket to catch it. or you'll have a mess.
Takes a half hour to change in the drive way
Going to drilling the filter next time , thanks for the tip.
Rocweiller is offline
post #12 of 12 Old 10-24-2018, 04:16 PM
Quoted: 17 Post(s)
If you plan to change your own oil, I would recommend installing an oil drain valve in place of the factory plug.
My 2006 6.0 had a drain plug on the bottom of the pan and was very easy to hit the drain pan.
On the 6.7, the plug is on the back of the pan and when removed shoots a stream of oil about 1.5-2' from the drain.
I discovered this my first oil change much to my wife's chagrin as it stained the concrete even though I had a large sheet of "just in case" cardboard under it.
I use Mobil1 0W40 available in 5qt jugs. I prefer the new style canister filter over the 6.0's filter element-less mess.
Just some thoughts after I learned my lesson after my first oil change on the 6.7L
thekroog is offline
