Regen while driving - Page 3 - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 13Likes
post #21 of 27 Old 04-05-2018, 08:06 AM
The truck doesn't "dump" DEF during a regeneration. It adds fuel to burn off the soot. the DEF is not related.
mfear is offline
post #22 of 27 Old 04-05-2018, 08:48 AM
Quoted: 36 Post(s)
As someone previously said, "don't over think things" find a good additive, a good filling station and stick with it. Stay away from mixing your own snake oil potions in an attempt to head off problems. You're still under warranty, if something craps out, bring it back to the dealer...
rcg270 is offline
post #23 of 27 Old 04-06-2018, 03:27 PM
nomad430's Avatar
Quoted: 7 Post(s)
Also put it in tow/haul when in town, it help keep the egr cleaner
Sent from my SAMSUNG-SM-G890A using Tapatalk
nomad430 is offline
post #24 of 27 Old 04-06-2018, 06:40 PM
Quoted: 50 Post(s)
Originally Posted by The Evil Twin View Post
The DEF is continuously injected into the exhaust during operation.
Actually DEF is only injected when you have high combustion temps.
If you are just idling along and seeing 300 EGT temps No DEF is being injected.
You climb a grade, Tow a load. or just plain Punch it away from a taffic light, and Tubo pressure goes up and your EGT temps climb and DEF gets injected.
This is why some folks see 1000 miles per gallon of DEF and others see 600 miles per gallon
DEF is injected in the SCR (Selective Catalyst Reduction ) portion of your exhaust system.
Regen is done in the DPF ( Diesel Particulate Filter) portion of your exhaust.
Two different pollution devices that happen to reside in the cruise missile assembly under your truck
2017 F350 CCLWB Platinum, Leveled, BAK MX4, Ultra Predator Wheels and Toyo A/TII 295/65R20 tires
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #25 of 27 Old 04-06-2018, 06:58 PM
The Evil Twin's Avatar
Quoted: 165 Post(s)
I'm newer to the new types of diesels, by everything Ive read is that DEF is used continuously while in motion. Some times more, others less but always injected.
Do you have more info on how Ford does it? I figures they were all the same.
2015 Oil Burner
CCLB Lariat Ultimate, 10k, Plow Package.
Mods have begun: 2wd Valance, Bully Dog GT, smoked lenses
The Evil Twin is offline
post #26 of 27 Old 04-07-2018, 02:35 PM
Quoted: 50 Post(s)
You can learn more about the SCR in the 6.7L Coffee Table book on page 82 ( the version I have)
You have a NOx Sensor that talks to the PCM via the CAN2 bus. The PCM controls the DEF Dosing Module.
I don't see any discussion of what levels of NOx that trigger the Dosing. So maybe it does continuously and only the amount is variable,
post #27 of 27 Old 04-07-2018, 05:36 PM
Just a Husband and Dad
auburnalum's Avatar
Quoted: 26 Post(s)
My first Regen hit last night at 575 miles on the clock. While driving. I noticed the fuel economy taking a huge dive coming back from a date nite with my wife. Then I let it run until it was done. Could smell that funky smell folks describe along with a lot of heat out the pipe.
After it all was done, there was no noticeable decrease in DEF level. None.
2018 F-250 Lariat Ultimate Stock for now
auburnalum is offline
