Tire size - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 2Likes
post #1 of 14 Old 12-20-2017, 01:49 PM Thread Starter
Stroked X's Avatar
Quoted: 8 Post(s)
Garage
Tire size
What is the largest tire you can fit on a stock 2017+ super duty with 20 wheels with no rubbing
Sent from my iPhone using Tapatalk
2018 F-350 Lariat
Stroked X is offline
post #2 of 14 Old 12-20-2017, 03:18 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 871 Post(s)
Feedback Score: 3 reviews
35" tires.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 14 Old 12-20-2017, 05:11 PM
Quoted: 4 Post(s)
Are you able to run 35's without rubbing if on 18" rims?
DieselFirst is offline
post #4 of 14 Old 12-20-2017, 06:26 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 603 Post(s)
Feedback Score: 11 reviews
yes. 285X75R18
HeavyAssault and Austinite79 like this.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #5 of 14 Old 12-20-2017, 09:47 PM Thread Starter
Stroked X's Avatar
Quoted: 8 Post(s)
Garage
Will a 35x12.5x20 fit or is it too wide
2018 F-350 Lariat
post #6 of 14 Old 12-21-2017, 05:10 AM
BBBRRRRRTTTTT
Quoted: 603 Post(s)
I have slight rubbing at full lock with 35x12.5r18
The Following User Says Thank You to powerstrokeshellback For This Useful Post:
Stroked X (12-21-2017)
post #7 of 14 Old 12-21-2017, 03:05 PM
Quoted: 17 Post(s)
My issue is this (from an admittedly anal-retentive sort)... Yes, you can put a 35 X 12.5 X 20 on a stock wheeled truck. (I saw a truck with 37 x 12.5 x 20 on a 2017 F-250 yesterday. That said, 35" wheels are meant to be mounted on wheels not less than 8.5" wide - 11" wide (10" being optimum). I think the stock wheel is 8" wide. While people are doing it, I think it looks silly to have sidewalls tucked in tight on a wheel that is really too narrow for the tire, not to mention the "crowning" wear by virtue of the tread not sitting in uniform fashion on the pavement. I am leveling mine and installing 20" x 9" American Force alloy wheels, and am still concerned about this concept, albeit less than the scenarios I detailed above. The whole "tucked in" side wall looks like cr-p IMHO. Again, this is my opinion only...
AND this effect is exacerbated with 20" wheels, as the distance from the wheel edge to the tread is that much shorter than a 17" or 18" wheel, thus making the sidewall "suck in" at an even steeper angle to fit inside the wheel...
GARBAJ is offline
post #8 of 14 Old 12-21-2017, 03:50 PM
BBBRRRRRTTTTT
Quoted: 603 Post(s)
My tires recommended 8-10 wide rims. They are 18s though. Not sure of how much a difference that makes.
post #9 of 14 Old 12-21-2017, 03:58 PM
Quoted: 17 Post(s)
Yes, in fairness, I'm quoting recommendations for 20" wheels. With 18" wheels, the sidewall doesn't have the same compression over such a short distance, so I can see width specs as different from 20s.
GARBAJ is offline
post #10 of 14 Old 12-21-2017, 08:21 PM
BBBRRRRRTTTTT
Quoted: 603 Post(s)
Makes sense. Gotta check the tire manufacturer website.
