Lordy....what oil? - Page 4 - Ford Powerstroke Diesel Forum
General 6.7 Discussion (2017-2019) General 6.7 Discussion
 32Likes
post #31 of 56 Old 12-02-2018, 02:38 PM
Rocweiller's Avatar
Quoted: 68 Post(s)
Originally Posted by auburnalum View Post
Originally Posted by Rocweiller View Post
I went with Schaefer’s 5w-40 full synthetic.
I have just tried Schaeffer's 722 10w-30. I am not hauling heavy so stayed with 10w-30. I just submitted my sample to Blackstone Labs for analysis. The first 9K+ I ran standard Motorcraft 10w-30 dino oil. Attached are my results of the first two changes. <img src="https://www.powerstroke.org/forum/images/Powerstroke_org_2015/smilies/tango_face_glasses.png" border="0" alt="" title="Nerd" class="inlineimg" />
I plan on doing an oil analysis after my second oil change with the shaeffers just to make sure I get all the original oil filtered out for the most part. So it’s going to be a bit since I don’t rack up the miles on my mistress.
Rocweiller is offline
post #32 of 56 Old 12-02-2018, 04:13 PM
Rocweiller's Avatar
Quoted: 68 Post(s)
So 10w 30 is a better option vs 5w 40 if truck is not a heavy hauler?
post #33 of 56 Old 12-03-2018, 07:56 AM
Quoted: 331 Post(s)
10-30 is the non-severe oil recommended by Ford. 5-40 is recommended for severe as defined by:
  • Frequent or extended idling (over 10 minutes per hour of normal driving).
  • Low-speed operation/stationary use.
  • If vehicle is operated in sustained ambient temperatures below -9F (-23C) or above 100F (38C).
  • Frequent low-speed operation, consistent heavy traffic less than 25 mph (40 km/h).
  • Operating in severe dust conditions.
  • Operating the vehicle off road.
  • Towing a trailer over 1000 mi (1,600 km).
  • Sustained, high-speed driving at Gross Vehicle Weight Rating (maximum loaded weight for vehicle operation).
  • Use of fuels with sulfur content other than ultra-low sulfur diesel (ULSD).
  • Use of high-sulfur diesel fuel.
auburnalum likes this.
jd4010 is offline
post #34 of 56 Old 12-03-2018, 02:19 PM
Rocweiller's Avatar
Quoted: 68 Post(s)
Thanks for that info , I may be a good candidate for 10w -30
post #35 of 56 Old 12-03-2018, 04:38 PM
Fishsizzle's Avatar
Quoted: 139 Post(s)
Garage
I have a few on those list so 5w-30 will stay in. I received my first Blackstone, which was residual T6 with new Schaffer and Arch oil. Forgot to change it Hot so I will see this next one with just Schaffer and Arch what kicks out with the report.
2017 F250 CrewCab Short, leveled with 35/12.5/20 Toyo MT. Fuel 20x10
TOTALED: 2010 F-350 6.4 Crew-Short, Sinister Deletes, Coolant Filter. SCT with Tunes. CTS2 monitor, Mishi Rad, CFS Intercooler. Cold Side pipe, Down Pipe. 2.5 level, 295/65/20 Kenwood 9900 Apple Car Play
Fishsizzle is offline
post #36 of 56 Old 12-04-2018, 07:04 PM
Just a Husband and Dad
auburnalum's Avatar
Quoted: 26 Post(s)
Originally Posted by HeavyAssault View Post
MC 10w30 is a synthetic blend. Good looking report for a Ford branded oil.
Thank you for the correction. Also to note I have not experienced the typewriter tick that some have. I may go back to MC 10w-30 to save a few $$ long term.
2018 F-250 Lariat Ultimate Stock for now
auburnalum is offline
post #37 of 56 Old 06-06-2019, 08:57 PM
Quoted: 6 Post(s)
Garage
Anyone else have a very small yet annoying leak with the motor craft filters
No matter how much i tighten filter it seems to continue this after bringing engine to full temp for a few hours.
Sent from my iPad using Tapatalk
2017 F-250 Lariat
White Gold w/ Caribou Accent
Austinite79 is offline
post #38 of 56 Old 06-07-2019, 03:04 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 780 Post(s)
Feedback Score: 3 reviews
Make sure you are getting the old filter gasket off the filter base. That picture seems like you need to use some pre-workout before you install that filter.
Kryptic_361 likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #39 of 56 Old 06-07-2019, 05:03 AM
G8orFord's Avatar
Quoted: 2518 Post(s)
Garage
I let Ford do the first oil change on mine since I had it in for some recall work anyway. The filter looked about like yours after a while. I changed it the last time and it's fine. I've got about 10% left on the oil life meter and this is what it looks like.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
The Following 2 Users Say Thank You to G8orFord For This Useful Post:
Austinite79 (06-07-2019)
post #40 of 56 Old 06-07-2019, 07:21 AM
Quoted: 6 Post(s)
Garage
I fell victim to the old gasket sticking on the mount the first time I changed the oil. This is the third Oil change and the first time I am having this issue but I did confirm the old gasket came off and the mounting surface was clean and the new gasket had a good bit of oil on it during install. This is my first diesel and it seems that I have to use an abnormal amount of torque when seating the new filter.
Sent from my iPhone using Tapatalk
HeavyAssault likes this.
2017 F-250 Lariat
