6.7 oil - Page 2 - Ford Powerstroke Diesel Forum
 9Likes
post #11 of 40 Old 04-29-2015, 11:07 AM Thread Starter
twood71's Avatar
Quoted: 67 Post(s)
What does these numbers mean?
"to lubricate a wide range of diesel engines requiring API CI-4 PLUS, CI-4, ACEA E7 or JASO DH-1"
2015 Ford super Duty F-350 SRW 6.7L Power Stroke
2006 Ford Super Duty F-350 DRW 6.0 Power Stroke
twood71 is offline
post #12 of 40 Old 04-29-2015, 11:22 AM
Jason99's Avatar
This should tell you about everything you ever wanted to know and stuff you didn't care about
Reading an Oil Bottle in the United States - What do those API, SAE and ILSAC Numbers Really Mean?
2005 F-250 Lariat FX4
Sinister Coolant Filter
4" Catback Exhaust/No Muffler
Blue Spring Update
Edge CTS Monitor
X4 with WPE White Noise Tune
6.0 Hard Starts and No Starts? Check out DTR
Originally posted by Heavy_GD
#DTR4Life
Jason99 is offline
post #13 of 40 Old 04-29-2015, 09:51 PM
raftdaddy's Avatar
I run t6, if you look in your owners manual 5-40 covers all temps and all duties light or severe. I like to think that is what the truck was designed for. At very least it is easy,no worries about having to time your oil changes with the seasons.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
The Following User Says Thank You to raftdaddy For This Useful Post:
SkiSmuggs (04-30-2015)
post #14 of 40 Old 04-30-2015, 04:26 AM
Quoted: 188 Post(s)
Any of the 5W-40 synthetics should do well. I use T6 because it was $6-7 cheaper per gallon than Mobil Delvac and I couldn't find Delo 5w-40 at my Walmart.
2015 Ford F-350 XLT, PSD, CCSB, Ruby Red Metallic
2012 Cougar High Country 299RKS, Andersen Ultimate hitch.
1/77 Armor, 5th Mechanized Infantry, I Corps
SkiSmuggs is offline
post #15 of 40 Old 04-30-2015, 06:53 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
I personally in your situation would use and 0w40 or a 5w40 but I wouldn't use rotella. I'd use mobil or valvoline
johndeerefarmer likes this.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #16 of 40 Old 04-30-2015, 07:07 AM
Why not the Rotella? This is my first diesel, been running the Motorcraft conventional, but was looking at switching to synthetic (just ordered T6 actually). In my gas burner, I ran Amsoil, but buying 3+ gallons of Amsoil isn't cost effective
2014 F250 Platinum 4x4
4"-4Link BDS Lift, BDS Dual steering stabilizer, Fox 2.0 Shocks.
20" x 10" Fuel Rampage wrapped w / 35x12.50x20 Toyo's
AMP Power Steps
H&S MM w/ Gearhead Tunes / No Limits EGR Delete . Flo-Pro 4" downpipe back w / muffler S&B CAI.
[SIGPIC][/SIGPIC]
RigTrash601 is offline
post #17 of 40 Old 04-30-2015, 07:09 AM
Quoted: 188 Post(s)
I wouldn't mind a clarification on that. Rotella seemed to be an overwhelming favorite and I bought it for price, but I have an open mind.
post #18 of 40 Old 04-30-2015, 07:12 AM
Quoted: 278 Post(s)
I just don't think it's that good of an oil. I tried it in my 6.4 and got a bad uoa back on it and don't care to try it again.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
The Following User Says Thank You to strokinpower For This Useful Post:
post #19 of 40 Old 04-30-2015, 01:33 PM
j21black's Avatar
Quoted: 16 Post(s)
I agree about Rotella. Lots of guys run it, but I never will again. Ran it twice in my 6.4L, it wasn't uncommon to see temps in th 213 to 214 range just cruising the interstate. It always came out looking much dirtier and the second time I ran it I found some shavings on the drain plug.
Valvoline Blue Preimum never got over the 197-198 mark, and always came out much cleaner. Switched back to it after I found the shavings after Rotella run, and never saw the shavings again.
That's just my personal experience and thoughts on it. I never had it tested, so I can't say for certain, but I'll never put it in another of my trucks.
j21black is offline
post #20 of 40 Old 04-30-2015, 04:26 PM Thread Starter
twood71's Avatar
Quoted: 67 Post(s)
Originally Posted by j21black View Post
I ran the Valvoline 15W40 Blue Premium in my 6.4L - It ran on average 10 degrees cooler than Rotella and looked a lot better after an oil change. Will probably stick with it with this truck...
I'm from Mount Vernon, IN originally. Heading there tomorrow, where are you at in Southern IN?
Over here at Boonville. You filling up on diesel in evansville or your home town?
twood71 is offline
The Following 2 Users Say Thank You to twood71 For This Useful Post:
cmsww (03-28-2016)
