70mph Rear End Bounce-CCLB - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 27 Old 12-05-2014, 11:28 AM Thread Starter
Quoted: 5 Post(s)
I know the topic has been beat to death about the rear end bounce at 45-50mph but I am getting one at 70mph. It mostly happens on highways that are concrete instead of blacktop and it bounces enough that my kidneys hurt, my lunch is remixed internally to the point that it may no longer stay internal, and no one can even talk right. It's like the little frog hopper ride at the amusement part going berserk. It is an embarrassment to even have someone ride in the truck, the look of bewilderment on their face when the +$60K truck tries to shake them out the window on a normal highway. The truck is a 2015 crew cab long bed SRW FX4 with just under 9k miles. Any thoughts or fixes for this?
2015 F350 CCLB Lariat Ultimate FX4 6.7L
Black on Black
40/20/40 Front Bench
5th wheel prep
Camper Package
Dual Alternators
3.55 w/ Locking Diff.
A.R.E. Z-Series cap, AMP Research Power Steps, Bed Rug
FDuce is offline
post #2 of 27 Old 12-05-2014, 01:38 PM
T diesel's Avatar
Quoted: 21 Post(s)
This may help.....Roadmaster Active Suspension Kits | Helper Springs | Overload Springs FICM repair.com carry's them.
2013 F-250 lariat scsb FX4.
6.2. 3.73 lockers. Rear wheel liners.
Camper package. Pullrite 18K lb Superslide, Line X sprayed bed.
Krown rust protected.
"That which can be asserted without evidence, can be dismissed without evidence"
- Christopher Hitchens
T diesel is offline
post #3 of 27 Old 12-05-2014, 02:05 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 906 Post(s)
Feedback Score: 3 reviews
Mine does it as well. Since it's only doing it on concrete roadways I just accept it. I doubt there's any real solution that is worth the cash.
Officially The Biggest Midget In The Game
HeavyAssault is offline
The Following User Says Thank You to HeavyAssault For This Useful Post:
HD95flhr (06-18-2017)
post #4 of 27 Old 12-05-2014, 02:24 PM Thread Starter
Quoted: 5 Post(s)
I would like to just accept it but when I'm on a road trip it makes it tough not to come unglued.
Does anyone know if any of the Carli suspension kits will eliminate the bounce?
Black on Black
5th wheel prep
Camper Package
Dual Alternators
FDuce is offline
post #5 of 27 Old 12-05-2014, 02:26 PM
elephantrider's Avatar
Quoted: 205 Post(s)
friend just got rid of a 2013 for the same reason.
he took it to the dealer several times, but always
cannot replicate the customer complaint.
02 joke
Originally Posted by djone10 View Post
I just bought an 05 powerstroke 6.0.
Any tips on what should be changed/checked other than oil change??
Originally Posted by Rolfsted View Post
Everything
elephantrider is offline
post #6 of 27 Old 12-05-2014, 02:38 PM
N.S.D.Q.
Quoted: 906 Post(s)
It's a matter of the roadway separations are at the right distance to make the issue MUCH worse. It's a CCLB thing that seems to be livin' thru the model years.
Sure a suspension setup such as a Carli could help. I'm sure they can give you better advice over the phone.
post #7 of 27 Old 12-05-2014, 02:41 PM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
Read this. https://www.powerstroke.org/forum/sho...d.php?t=630442
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #8 of 27 Old 12-05-2014, 04:04 PM
Rattler1's Avatar
Quoted: 22 Post(s)
I am leaning towards it being a shock effectiveness issue. The SD shocks seem to be in almost as far as they can go away from the tires. In contrast the F150 doesn't seem to have this issue and their shocks are placed out as close to the tire as possible. The F150 comes in a long bed super cab as their longest model so it isn't quite as long but if it was a frame issue I'm confident they would have issues with their much lighter duty frames.
There is also plenty of chatter in the off road sites about moving shocks closer to the tires for better effectiveness.
2015 F250 XLT crew cab long bed 4x4.
Rattler1 is offline
post #9 of 27 Old 12-05-2014, 04:40 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I have some folks with the Ranchos say the opposite, they run smooth as Butta'
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #10 of 27 Old 12-05-2014, 05:54 PM
gone6.0's Avatar
Quoted: 31 Post(s)
I test drove a new supercab, when at 35 to 45 it had the same hop, when I rolled back in to the lot the salesman ask how i liked it, I told him about the hop and he said really thats the first complaint I have ever heard about.
2004 F250, SCSB, APR studs, Banks intercooler, Edge Insight, SCT with tune from Eric, atlas 40, deleted, 2" leveling kit, coolant filter, 6.4 banjo bolts with blue spring, Harpooned, Nathan K5LA. Nations 190 amp alt.
Twin Viair 480C's. BOSS superduty 8' poly plow.
gone6.0 is offline
