SEIC (High Idle) MOD PICTURES - Page 6 - Ford Powerstroke Diesel Forum
 2Likes
post #51 of 61 Old 10-09-2015, 02:37 PM
Quoted: 167 Post(s)
Garage
i don't have the upfitters in mine but i put some lighted 3 ways on my kick panel knee height. i have some on lights and one for my SEIC.
I put several resisters in series with a wishbone setup so i can flip switch down and get 1100 rpm or up and get 1500 rpm.
if anyone one need pics or diagrams ill make some in cad or ya. I do a lot of low voltage stuff as my career for the last 10+ years.
mwe_060 is offline
post #52 of 61 Old 01-22-2017, 05:20 PM
TX_TRU_STUD's Avatar
Quoted: 58 Post(s)
Hey guys, I just did the mod over the weekend and I found out what most of you probably know, remote start and high idle dont work. I found a seemingly complicated post about using relays to change all the upfitters to a 12v constant but didnt feel like doing that. I found a 12v constant wire in the wire harness under the door trim that did the trick for me.
So if you want to use high idle AND remote start your truck (which would seem like a given from Ford but it's not), I hooked everything up per the pictures in the first post but for the VP PWR or whatever wire (green and yellow), I ran that to a rocker switch I had and then to the WHITE w/ RED STRIPE under the door trim/kick panel. This allows me to flip the switch to ON (in the winter and I can set it to OFF when I dont want high idle) and leverage high idle via remote start. I put the switch under my steering column for now and the high idle potentiometer (pot) in the cubby by your right knee under the 12v cigarette lighter. Works great!
I hope this helps someone, as I didnt find anything on other sites after looking for a few days.
Here is the 50k pot I used.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Switch (extras for other projects if you want for the price of 1...)
https://www.amazon.com/yueton-Pack-2...=rocker+switch
TX_TRU_STUD is offline
post #53 of 61 Old 03-13-2017, 02:53 PM
Hi guys, this write up is awesome!! Im having trouble though. I hooked everything up per instructions with the 50K pot and its not working even with P brake applied. I used AUX#3 also. Nothing happened when I flipped the switch but when I started turning the knob the pot itself, the idle seemed to dip like I introduced a stumble, then came back up then no changes. Couldnt duplicate it again. I also let the p brake off and then reapplied, I got the big WRENCH Icon on the screen. Any ideas whats UP?
I have a 2013, is that the issue?
Pot is hooked to: white/brown stripe,- Green wire , -and Gray/Violet stripe
The Yellow/Green stripe wire is hooked to AUX3 wire
motionmatt is offline
post #54 of 61 Old 07-12-2017, 10:36 AM
Quoted: 8 Post(s)
So... the pictures arent available for me. Can everyone still see the pictures? I was thinking about doing this mod.
msk182 is offline
post #55 of 61 Old 07-12-2017, 11:00 AM
00blacky's Avatar
Quoted: 9 Post(s)
Nope. Pics are gone. You can thank Photobucket.
Static54 likes this.
-Jeff
14 6.7 F350 Platinum
00blacky is offline
post #56 of 61 Old 07-12-2017, 11:19 AM
Quoted: 94 Post(s)
@msk182 and all others interested in this, check this out on Rudys Diesel. Seems like a plug & play if you will instead of trying to find a Radioshack in 2017 when this thread started in 2010 lol
https://www.rudysdiesel.com/product-p/1036610.htm
Heavy_GD likes this.
HectorSaenz is offline
post #57 of 61 Old 07-13-2017, 06:57 AM
Quoted: 8 Post(s)
Oh awesome! Thanks!
Purchase.
msk182 is offline
post #58 of 61 Old 08-09-2018, 02:14 PM
CollinF250's Avatar
So before I do this guys does it matter if my trucks deleted?
Next Ive got the pot here and on the back theres two tabs are those for ground wires? Or are they not used?
TIA For answer
CollinF250 is offline
post #59 of 61 Old 08-09-2018, 03:49 PM
Quoted: 105 Post(s)
No, it does not matter if you are deleted or not.
The pot does not need to be grounded. Set the resistance for desired RPM. Then you connect the center tab and one of the outer tabs per the drawing/article.
https://madocumentupload.marketingas...b525f&v5=False
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #60 of 61 Old 08-10-2018, 03:39 PM
Hunter6146!!'s Avatar
Quoted: 16 Post(s)
Originally Posted by AggieStroke View Post
On location? You must be oilfield haha! Greetings from the great dusty West (Odessa)!
Sent from AutoGuide.com App
Heck yea....Safety Supervisor. Love it.
Sent from my iPhone using Tapatalk
Hunter6146!! is offline
