Water pump - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 11 Old 01-10-2020, 06:08 PM Thread Starter
Quoted: 10 Post(s)
Water pump
Just noticed a leak today coming from my secondary radiator so ordered a replacement from Mishimoto and a primary radiator from them. Figure get them both upgraded at once. Now my question is should I replace the main water pump while the front is torn apart? Truck has 73k miles on it currently.
Sent from my iPhone using Tapatalk
Joek6.5 is offline
post #2 of 11 Old 01-10-2020, 07:10 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 629 Post(s)
Feedback Score: 11 reviews
sorry to tell you but mishimoto has had a bad track record with powerstrokes...
HeavyAssault likes this.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #3 of 11 Old 01-10-2020, 07:18 PM
Quoted: 695 Post(s)
Sure it's the secondary rad that's leaking? while anything's possible, I have yet to see one of them fail.
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
post #4 of 11 Old 01-10-2020, 07:21 PM Thread Starter
Quoted: 10 Post(s)
Yeah Iím sure. Some cables for a winch rubbed into them.
Joek6.5 is offline
post #5 of 11 Old 01-10-2020, 07:35 PM
Quoted: 695 Post(s)
I see.
How much can you get a new pump for?
They certainly aren't uncommon to fail so if it's a decent price, I'd go ahead personally.
-Michelangelo
kaya is offline
post #6 of 11 Old 01-10-2020, 07:36 PM Thread Starter
Quoted: 10 Post(s)
I see.
It says 120 on Amazon for motorcraft.
Joek6.5 is offline
post #7 of 11 Old 01-10-2020, 08:21 PM
Quoted: 695 Post(s)
K yea I'd definitely do it. Much more comfortable than hanging over the grille, and the coolant will be drained anyways.
Just make sure to get the correct year. The later pump has two ports at the front while earlier years won't. You could still use it, but you'd need to buy the plugs, which Ford sells.
No point in adding other possible leak locations though.
ZMANN likes this.
-Michelangelo
kaya is offline
post #8 of 11 Old 01-11-2020, 05:38 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 952 Post(s)
Feedback Score: 3 reviews
Cancel that order before you start down the road. You will be in for some headaches down the road.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #9 of 11 Old 01-15-2020, 04:09 PM
Quoted: 340 Post(s)
I sure am glad I let my factory rad leak instead of jumping onto the mishi boat some years ago. Lo and behold, my rad doesn't leak anymore...fixed itself, I didn't do anything to it.
--H
2012 6.7
Too many toys for it to list
HLBeef is offline
post #10 of 11 Old 01-19-2020, 05:49 PM
Quoted: 38 Post(s)
Definitely x2, replace with oem radiator not mishimoto. Even the one on my dmax leaked after about 10k miles.
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
