Gearing change - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 14 Old 01-08-2020, 05:53 PM Thread Starter
Quoted: 10 Post(s)
Gearing change
Hey all just looking for some input on a possible gear swap. Currently have the 3.31 if I remember correctly and currently I average around 11.5 mpg. It’s a farm work truck/weekend adventure rig so it weighs in around 10k daily and currently have 36” Toyo mts on it. Was just wondering in my case if going up to 4.30 gears would help improve my mpgs and overall driving experience and towing experience?
Sent from my iPhone using Tapatalk
Joek6.5 is offline
post #2 of 14 Old 01-08-2020, 07:34 PM
Quoted: 38 Post(s)
You would really only notice that it won’t downshift into 5th as often because it won’t lug as much. 6.7s get poor fuel economy generally and if it weighs 10k and you tow with it, averaging 11.5 is totally normal. Most normal unloaded trucks get 13-14. It wouldn’t be worth the money in my opinion.
06 King Ranch
Fass 200, Custom fuel lines, 225/100s, Thumper stage 2 hpop, WPE stage 3 intake, Mishimoto radiator, Flex a lite fans, BPD water pump, MPD oil cooler relocate kit, Intercooler pipes, Compounds built by me, etc etc etc
05 Eddie Bauer
Resealed entire motor @ 170k miles, new lifters, 6.4 push rods, studs, rebuilt the turbo, IPR egr delete, new injectors, new heads, new ficm board, coolant filter, intercooler tubes, regulated return, bunch of other new parts. Factory exhaust, cat gutted(wife's rig). Livewire with gearhead tunes. Should go a while reliably for her!
03 LB7 duramax the "daily/tow pig"
Lbz cp3, s475/stock twin kit, built trans, steel driveshft, amsoil bypass, secondary oil cooler built by me, fass, traction bars, trans cooler upgrade, dual alts, straight center link + tie rod sleeves, efi live, transfer flow/tool box tank, 5er hitch, other small upgrades.. and most importantly, STOCK HEADBOLTS! Just rolled 200k miles, twins installed @ 165k, daily driven on a "550 tune" tows 18k on a "475" tune.
Nickjames525 is offline
post #3 of 14 Old 01-08-2020, 08:06 PM
Quoted: 27 Post(s)
I've regeared a few rigs (keeps). And honestly could never tell a difference after the gear swap.
2015 F250 XLT
redxjer is offline
post #4 of 14 Old 01-09-2020, 04:02 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 955 Post(s)
Feedback Score: 3 reviews
For the costs of the gear swap that's a lot of fuel to buy. 4.30s aren't going to gain you any significant MPGs.
Spirit likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #5 of 14 Old 01-09-2020, 06:25 AM
18M_RWR's Avatar
Quoted: 47 Post(s)
Gearing change
Going up in gear ratio will increase the engine RPMs in all transmission gears so it will further decrease your fuel mileage not help it. Going from the lowest gear ratio offered to the 2nd highest gear ratio offered will increase your engine RPMs by a few hundred at least. As others have said the engine will lug less and you’ll be able to pull any longer/steeper hills easier but fuel mileage will be worse. My dually has 4.30 gears in it and with 33” tires on it now it turns 1750RPMs @ 60MPH. With the stock 31.5” tires it used to turn 1850RPM @ 60MPH.
μολὼν λαβέ | si vis pa·​cem, pa·​ra bel·​lum
2016 F350 Lariat 6.7L CCLB DRW 4WD 4.30LS
14000#GVWR Pkg, HiCap-TowPkg, PlowPkg-ExtraHD Alt, WideTrack frt axle, Max frt springs
Sinister ColdSide Charge Pipe, OBDLinkMX+ MonitorApp on Fire7 tablet
18M_RWR is offline
post #6 of 14 Old 01-09-2020, 08:38 AM Thread Starter
Quoted: 10 Post(s)
Thanks for all the info looks like gear change won’t be happening then. Ha
Joek6.5 is offline
post #7 of 14 Old 01-09-2020, 08:40 AM Thread Starter
Quoted: 10 Post(s)
Thanks for the info. Sometimes I feel like my truck is sitting at too low of an rpm in 6th gear is another reason I was thinking of swapping gears. Currently it’ll be around 1200ish rpm at 60 mph.
Joek6.5 is offline
post #8 of 14 Old 01-09-2020, 10:40 AM
18M_RWR's Avatar
Quoted: 47 Post(s)
A 36" tire is approximately 113" in circumference and will make 561 revolutions/mile.
Your 3.31 gears have a final axle/tire ratio to engine RPMs of 2.23 in 6th gear [3.31x0.674(6th gear ratio of 6R140 transmission)] so going 60MPH on your 36" tires you should be turning roughly 1250RPMs [561x2.23=1251]
So if you put 4.30 gears in it your final axle/tire ratio to engine RPMs would be 2.89 in 6th gear (4.30x0.674) and going 60MPH on your 36" tires you should turn roughly 1625RPMs. Those roughly 400RPMs will make the engine thirstier for certain. But I understand why you are looking to change your gearing.
So here are the different rear-end gear ratios and roughly what the engine RPMs would be on 36" tires going 60MPH in 6th gear:
3.31 gears = 1250 +/-
3.55 gears = 1342 +/-
3.73 gears = 1410 +/-
4.10 gears = 1550 +/-
4.30 gears = 1625 +/-
Hope that helps some.
18M_RWR is offline
The Following User Says Thank You to 18M_RWR For This Useful Post:
afhanson72 (01-09-2020)
post #9 of 14 Old 01-09-2020, 03:03 PM Thread Starter
Quoted: 10 Post(s)
Thanks a ton that’s actually extremely helpful!
18M_RWR likes this.
Joek6.5 is offline
post #10 of 14 Old 01-09-2020, 03:43 PM
Quoted: 530 Post(s)
Garage
One other thing that need to be considered in axle ratios, is engine load
The more load that is on a diesel the more fuel it uses
so, even tho the 4.30 gears cause more RPM, they also cause less load
less load = less fuel
so both factors need to be considered when choosing a axle ratio
The 3.73 may be a more middle of the road choice
another thing, is body height, ...lifted trucks have more air turbulence under the body
you see these little rice burners with a 2 inch road clearance, ...that is part of how they get good mileage
18M_RWR likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
