Buying truck that has emissions system bypassed - Ford Powerstroke Diesel Forum
 15Likes
post #1 of 35 Old 01-08-2020, 01:13 PM Thread Starter
Found a 2015 f250 I may possibly buy. The truck has 100k miles. The person said they were having an issue with the DEF system. So they just went ahead and bypassed the DEF system, EGR, and the DPF. do you think this would be a good buy. Or should I avoid a truck like this?
kyle308 is offline
post #2 of 35 Old 01-08-2020, 01:17 PM
jman37's Avatar
Quoted: 400 Post(s)
Garage
Do you need to pass emissions to get a sticker every year? If so then it will not pass and you'll be stuck fixing whatever the issue is. If not then I would still look into it. Any maintenance records available? What are they asking for it? What tune is it running right now?
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #3 of 35 Old 01-08-2020, 01:19 PM
roverjosh's Avatar
Quoted: 51 Post(s)
Garage
SO many questions....
But my big question would be "What issues were they having?" I.e.: codes etc.... did they delete and put a wicked tune on it and drag racing or was it just a few blown sensors and they decided to delete to bypass the expense of repair?
Also, condition the truck? what was it used for? See if someone (a ford mechanic or someone nice with access) can pull an Oasis report on it for you.... you'll need the VIN.
Just my 2 cents.
When it comes to mechanics, everything I know is from either breaking it or watching someone else do the same. Then I had to fix it....Is that bad?
Murphy's Law: "things will go wrong in any given situation, if you give them a chance."
roverjosh is offline
post #4 of 35 Old 01-08-2020, 01:21 PM Thread Starter
I do not. There are no inspections in my state. It was a company vehicle. The person that purchased it said the check engine light was on. There was a problem with the DEF system. So they bypassed all the emissions stuff. Its stock tuning. The only thing they have done is bypass that stuff. The vehicle is at a dealership.
kyle308 is offline
post #5 of 35 Old 01-08-2020, 01:24 PM Thread Starter
But my big question would be "What issues were they having?" I.e.: codes etc.... did they delete and put a wicked tune on it and drag racing or was it just a few blown sensors and they decided to delete, to bypass the expense of repair. They're asking 17k.
Just my 2 cents.
The truck is in great shape. It has some scratches and dings in spots from being a work truck. They told me that it was all bypassed because they didnt want to pay to fix the emissions stuff. They're asking 17k.
kyle308 is offline
post #6 of 35 Old 01-08-2020, 01:25 PM
jman37's Avatar
Quoted: 400 Post(s)
Garage
Well it's not stock tuning because the truck wouldn't run if it was the way it is right now.
jman37 is offline
post #7 of 35 Old 01-08-2020, 01:28 PM Thread Starter
Ok. The guy said the only thing they had changed was in the computer to bypass emissions. I didnt ask about any specific tuning changes.
kyle308 is offline
post #8 of 35 Old 01-08-2020, 01:29 PM
jman37's Avatar
Quoted: 400 Post(s)
Garage
Well this is stuff you should ask and find out. If the truck was "rigged" to bypass that stuff with no proper tune, I'd pass on it. And how much are they asking anyways?
HeavyAssault likes this.
jman37 is offline
post #9 of 35 Old 01-08-2020, 01:30 PM Thread Starter
They're asking 17k for it
kyle308 is offline
post #10 of 35 Old 01-08-2020, 01:38 PM
Quoted: 105 Post(s)
MAKE SURE YOU GET THE TUNER AND TUNES with the truck......DO NOT BUY IT WITHOUT THE TUNER...
MrTommy and Grish76 like this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
