Park lights on a 2015 f350 - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Larry1013
post #1 of 3 Old 11-14-2019, 01:13 PM Thread Starter
If I leave my park lights on should they turn off by timer? My headlights will but my park lights will not if I leave them on..any help would be as appreciated!
toystuff is offline
post #2 of 3 Old 11-14-2019, 01:43 PM
Quoted: 105 Post(s)
if you leave the light switch set to park lights, I do not think there is a timing circuit to cut them off.
From the 2015 Ford Service DVD
Exterior Lighting
NOTE: The cargo lamp and running board lamps are covered in Section 417-02 .
Battery Saver
NOTE: Time-out is 1 minute if the vehicle has less than 80 km (50 miles).
The battery saver is internal to the Body Control Module (BCM) and provides automatic shut-off of the headlamps and parking lamps after 10 minutes in order to save battery voltage. A timer is started when the ignition switch is changed to the OFF state with the headlamp switch in the HEADLAMPS ON position, or the headlamp switch is placed in the HEADLAMPS ON position with the ignition switch off. When 10 minutes have elapsed, the voltage is automatically shut off to the lamps by the BCM .
The battery saver does not control the parking lamps if the headlamp switch is in the PARKING LAMPS ON position.
The timer restarts (and voltage is restored if the BCM had the voltage disabled) if any of the following occurs:
The ignition state is changed to any state other than OFF.
The headlamp switch position changes.
Any door becomes ajar.
The UNLOCK button of the Remote Keyless Entry (RKE) transmitter is pressed.
A valid keypad code is entered.
The instrument panel dimmer switch is pressed
HeavyAssault likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 3 Old 11-14-2019, 06:46 PM Thread Starter
Thanks Larry
Just wanted to make sure that was right or figure out how to fix it if it wasn't.
toystuff is offline
