Best addititve to avoid HPFP failure - Page 2 - Ford Powerstroke Diesel Forum
 13Likes
post #11 of 17 Old 11-01-2019, 04:50 AM
UR2EZ's Avatar
Quoted: 69 Post(s)
Originally Posted by rspeer View Post
Iíve been considering adding a DPK and/or an Exergy inlet metering valve. I run PM22A in every tank but with just shy of 130k on the clock, not sure how far I want to push it.
Sent from my iPhone using Tapatalk
I would put it on there as soon as possible. Trust me, you don't want that bill without it. $11k - $13k isn't chump change.....for most of us
Sent from my SM-G975U using Tapatalk
UR2EZ is offline
post #12 of 17 Old 11-01-2019, 06:00 AM
rspeer's Avatar
Quoted: 5 Post(s)
I hear you. Iím still gathering info on that Exergy metering valve. That may be what I end up doing. Pretty non-invasive and makes logical sense to me in theory. I need to talk with a couple more people before I do anything.
18M_RWR likes this.
rspeer is offline
post #13 of 17 Old 11-01-2019, 06:23 AM
UR2EZ's Avatar
Quoted: 69 Post(s)
Personally, I would look to replace the lift pump too. Either with an AirDog or FASS. They will provide adequate fuel to the CP4 and eliminate the air bubbles which in turn helps with lubricity. Lack of lubrication is the cause for failure of the CP4. They're a little pricey but it's solid insurance considering
HeavyAssault likes this.
UR2EZ is offline
post #14 of 17 Old 11-01-2019, 03:12 PM
JJMassar's Avatar
Quoted: 16 Post(s)
Garage
I used Diesel Kleen for a while and switched to the Motorcraft Diesel Additive recently. Truck runs best on the Motorcraft for sure.
JJMassar is offline
post #15 of 17 Old 11-01-2019, 03:46 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 928 Post(s)
Feedback Score: 3 reviews
I'm with @UR2EZ . Using a low pressure feed pump like the AirDog will add extra filtering, water removal, and air removal that can't hurt. Now just figure out what fuel additive you want to use.
UR2EZ likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #16 of 17 Old 11-01-2019, 03:48 PM
UR2EZ's Avatar
Quoted: 69 Post(s)
I was using Diesel Kleen when my HPFP went out. Now I use Hot Shot Secret. Only time will tell but I did put an AirDog II 4g 165 on her as well; along with a ton of other upgrades since everything was ruined
UR2EZ is offline
post #17 of 17 Old 11-01-2019, 07:52 PM
JJMassar's Avatar
Quoted: 16 Post(s)
Garage
I should also add that I do have a FASS Pump installed on my truck as well.
UR2EZ likes this.
JJMassar is offline
