HPFP Failure!! - Page 4 - Ford Powerstroke Diesel Forum
 41Likes
post #31 of 42 Old 10-31-2019, 11:27 AM
My research suggests that Ford owners have been luckier than Chevy/GMC folks because they have an electric fuel pump before the CP4. Their is currently a lawsuit going forward against Chevy/GMC that the CP4.2 was a bad choivce because of poor diesel quality in the US and the high failure rate. A lot of the failures are also a result of low fuel pressure/air in the pump. This compounds the lack of lubricity in the entire system.
I was just thinking the other day about all the filters and fluids I use for my 2005 6.0L versus any gasser I have ever owned. I started thinking if there is something that I can start doing for them to match what I am doing my 6.0L.
spookctr is offline
post #32 of 42 Old 10-31-2019, 11:20 PM
I have a 2011 F350 with a 6.7 diesel in it and have used always Howes fuel additive. I have over 770,000 miles on it and have never had a fuel issue. I did cut my last fuel filter open and checked for any metal particles with a magnet and could find nothing. I guess I have just been lucky. I have just recently started to occasionally have a fuel injector code and will probably end up just changing all of them to be safe. With all of the issues I have read about the high-pressure fuel pumps it sure sounds like I have dodged a bullet.
Ghostrider33 is offline
post #33 of 42 Old 11-01-2019, 03:13 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 924 Post(s)
Feedback Score: 3 reviews
Originally Posted by Ghostrider33 View Post
I have over 770,000 miles on it ......
That's impressive!!! Keep rollin'!!!
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #34 of 42 Old 11-01-2019, 05:03 AM
Quoted: 2 Post(s)
Did Ford fix this problem after 2014? I have a 2016 with 80k on it. Never used additive. I see a $350 fix on Amazon. After reading this post, I will start using fuel treatment (what can it hurt?) just wondering if I need to buy and install the fix?
Blaigle is offline
post #35 of 42 Old 11-01-2019, 05:06 AM
UR2EZ's Avatar
Quoted: 69 Post(s)
No, they did not and I highly suggest you use a decent additive with every fill-up, name brand diesel, drain the separator at least every month, and install the disaster prevention kit. I have a 2016 and mine went out over the summer at around 54k miles and I did all of that, minus the kit. Didn't know about the issue until it was too late
Sent from my SM-G975U using Tapatalk
UR2EZ is offline
post #36 of 42 Old 11-01-2019, 05:38 AM
Quoted: 2 Post(s)
Thank you, I am going with Howe’s for now, kit gets here on Sunday. I have always stuck by my Ford trucks, but they are making it difficult. Shame on Ford.
Blaigle is offline
post #37 of 42 Old 11-01-2019, 05:45 AM
UR2EZ's Avatar
Quoted: 69 Post(s)
It's not just Ford that uses that HPFP. I do think a lot has to do with the stock lift pump being too weak in the Ford's though. I went ahead and replaced everything with upgraded parts and deleted the entire stock fuel and filtration system when mine went out so hopefully I won't have anymore issues. Put the kit on there as well. Hope this helps
UR2EZ is offline
post #38 of 42 Old 11-01-2019, 06:32 AM
Quoted: 4 Post(s)
Interesting that someone brought up the dieselsite filter kit to add in more filtration to the system. By my understanding that kit goes down to 2 microns but the factory ford filter (top by the engine) only goes down to 4 microns. Being that the dieselsite kit is plumbed in before any of the ford fuel filters and it has a lower micron rating, wouldnt it make the factory system pointless (in a way) because it has already filtered out more than the factory system can? Makes more sense to me to have that lower micron rating last in line before the high pressure pump not first? Not an expert here just trying to make sense of that whole concept. Someone who knows more please correct/ educate me if I'm mistaken
RROUTLAW is offline
post #39 of 42 Old 11-01-2019, 08:36 AM
edreddy's Avatar
Quoted: 4 Post(s)
Garage
BTW - we should sticky this topic. Who can we get to do this?
HeavyAssault likes this.
2013 Silver F-350 CREW 6.7L 4x4 Lariat.
edreddy is offline
post #40 of 42 Old 11-03-2019, 11:07 PM
Quoted: 40 Post(s)
I am running the Diesel Site dual filter kit on my 14. When I spoke to them they did state it was 2 microns filtration. When I asked why so low they stated it would not allow water to pass. I would love it if someone could confirm this in testing or some other way.
Tom
2014 XLT Premium CC Dually 2WD, Remote Start Added, Diesel Site Dual Filters, Rudy's Cold Air Pipe, Infotainment Radio Swap + Rear Camera Added
2002 XLT CC Dually 2WD, 6 Spd, True Workhorse that kept going.
1999 F250 Lariat CC LB SRW 2 WD, Automatic. Just didn't perform towing.
tomshep is offline
