Wiring harness on frame rear of truck ? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By mark00jeep
post #1 of 8 Old 10-20-2019, 07:49 AM Thread Starter
mark00jeep's Avatar
Garage
I have a Wiring harness on the frame inside next to the spare tire. I'm looking to put a 7 way plug inside the bed wall. Could I be lucky enough that this would be a harness for just such a thing. 2011 F 250 FX4 Thanks for your help.
ID:	724245   Click image for larger version
mark00jeep is offline
post #2 of 8 Old 10-20-2019, 09:27 AM
Quoted: 105 Post(s)
Those appear to be the 7 pin trailer plug connectors. There might be another pair similar to these on the driver side frame near the rear bumper side of the left rear tire.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 8 Old 10-20-2019, 08:48 PM
Quoted: 39 Post(s)
You need to research using the OEM bed plug. Search on ebay. I believe it is offered with a T-connector that goes right in your OEM harness and spacer for the 7 pin plug in the bed.
Tom
2014 XLT Premium CC Dually 2WD, Remote Start Added, Diesel Site Dual Filters, Rudy's Cold Air Pipe, Infotainment Radio Swap + Rear Camera Added
2002 XLT CC Dually 2WD, 6 Spd, True Workhorse that kept going.
1999 F250 Lariat CC LB SRW 2 WD, Automatic. Just didn't perform towing.
tomshep is offline
post #4 of 8 Old 10-21-2019, 03:14 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 871 Post(s)
Feedback Score: 3 reviews
Those are the connections for the OEM in bed connector when you order the OEM gooseneck hitch setup. Personally there are plenty of online sources for OEM parts so order with confidence.
With that, mounting the OEM in-bed connection might be a bit of a hassle. It's not a simple round hole to cut to make it fit nice. When you get the parts in hand you will see it's not a huge issue.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #5 of 8 Old 10-21-2019, 05:01 AM Thread Starter
mark00jeep's Avatar
Garage
Thank you all for the information. These plugs are located on the left side/ driver side under the bed. I have the plug on the bumper. But I want to be able to plug in on the inside of the bed with my 5th wheel.
HeavyAssault likes this.
post #6 of 8 Old 10-21-2019, 11:23 AM
N.S.D.Q.
Quoted: 871 Post(s)
So you need this:
post #7 of 8 Old 10-21-2019, 11:25 AM
N.S.D.Q.
Quoted: 871 Post(s)
And here on the receiver hitch when connected:
post #8 of 8 Old 10-21-2019, 11:35 AM Thread Starter
mark00jeep's Avatar
Garage
Outstanding,. Thank you so much. Ordering one soon. Thanks to all for the information.
