2016 F-250 xlt cc. Gas vs diesel. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-16-2019, 09:27 AM Thread Starter
Quoted: 3 Post(s)
At a nearby dealership there is two 2016 F-250 xlt crew cabs. The gas truck has 55,000 miles priced at 30,000 and the diesel has 38,000 miles priced at $38,000. I currently have a regular cab 2012 F-250 that I use to plow in the winter and to haul my 31 foot 5th wheel in the summer. I am looking to upgrade to a crew cab for camping. I have a company truck to drive so I mainly use the truck to plow and tow and occasionally drive to the store. I know the 6.2L can pull the camper but I don’t necessarily like the high rpm’s and fuel mileage. I was wondering if it’s actually worth the extra money to buy a diesel. I have read that the 2016 6.7L is a good motor with few problems but the possibility of spending thousand of dollars to fix a broke engine worries me. I would like the increase mileage during towing and extra power but is it worth it?
Shakes95 is offline
post #2 of 11 Old 10-16-2019, 09:53 AM
jman37's Avatar
Quoted: 360 Post(s)
Garage
That's a choice you'll have to make for yourself. Is the 6.7 better than the 6.2? Yes. They both have their quirks. The 6.7 will cost more for maintenance, and yes it can be scary if you've never had a diesel before and repairs are at least doubled what a gas motor would cost. If your anal and don't mind crawling under the truck every few weeks to drain the separator, always make sure you go to a good fuel station and use an additive, then go for it.
If it bothers/scares you, then stick with the 6.2. You can put regular gas in it, not have to worry, and it will still have the pulling power you need. The price difference is really a moot point between the 2, so it comes down to what YOU would rather deal with, knowing what you may come across.
The emissions on the 6.7 are good and with that low of mileage I wouldn't expect you to have any problems with it. The EPA is really cracking down on "off road" use diesels.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #3 of 11 Old 10-16-2019, 10:58 AM Thread Starter
Quoted: 3 Post(s)
Doing preventative maintenance such as oil changes and fuel filters wouldn’t be a problem. Is there any known problems with the 2016 6.7 diesels? I’d keep mine stock as I’m not into modded trucks.
Shakes95 is offline
post #4 of 11 Old 10-16-2019, 11:14 AM
jman37's Avatar
Quoted: 360 Post(s)
Garage
Like I said, if you don't care for the fuel system, it can come back to haunt you. Any bit of water from bad fuel could result in a $10k repair bill from a dealer if your INS company wouldn't cover that.
jman37 is offline
post #5 of 11 Old 10-17-2019, 06:57 PM
Quoted: 46 Post(s)
Hands down that diesel is going to pull so much better than the 6.2. Cost more to maintain, drive and likely stress you more. If you think it will net you better fuel milage for that size camper, you can forget it.
I was in similar situation 4 years ago when I bought mine. Wanted diesel and nothing was changing my mind. Got it and have zero intentions of ever going back to gas. Just something I've accepted. Good luck with your decision.
2012 F250 Crew Lariat FX4
Stock? Sure, that's what we'll call it.
Grish76 is offline
post #6 of 11 Old 10-18-2019, 02:10 PM Thread Starter
Quoted: 3 Post(s)
What year truck did you get and have you had any problems with it? What kind of mpg can I expect while towing something as big as my 31 foot 5th wheel camper weighing around 10k.
Shakes95 is offline
post #7 of 11 Old 10-18-2019, 02:43 PM
7.3lf550's Avatar
Quoted: 77 Post(s)
The MPG will vary based on a multitude of things. However, under no circumstances, will it be cheaper to run the diesel truck.
Gas engine-9MPG
100k miles
11,110 gallons of gas
@ 3$ a gallon
=33k in gas
diesel-14mpg
100k miles
7142 gallons of fuel
@3.50 a gallon
=25k in fuel.
That assumes 100k miles of towing.......Empty the fuel mileage difference will be negligible.
So you will save 7k dollars in fuel over 100k miles of TOWING.
It costs more than 7k extra to buy a truck with a diesel.
Only buy a diesel if you WANT one, or if you tow heavy. Either is a good reason.
(Obviously all numbers are speculative based on my personal experience.)
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #8 of 11 Old 10-19-2019, 06:09 AM
Quoted: 46 Post(s)
Mine is a 2012 Lariat FX4 and I get around 10mpg with my 32' bumper pull. The only thing I've had go wrong is the radiator replacement. With you looking at a 16 YM you'll have the better turbo which sold pull even better and possibly net you a little better fuel milage. All just depends of conditions at time of towing.
Grish76 is offline
post #9 of 11 Old 10-19-2019, 07:13 AM
00t444e's Avatar
Quoted: 574 Post(s)
Doing preventative maintenance such as oil changes and fuel filters wouldnít be a problem. Is there any known problems with the 2016 6.7 diesels? Iíd keep mine stock as Iím not into modded trucks.
All of the new diesels have problems with the emissions equipment, like the EGR, DPF, and SCR. If your going to keep the truck stock I would get the gas engine. The gas engine will be slower on the hills and it will use more fuel, but it's worth not dealing with all of the headaches caused by the emission on a diesel.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #10 of 11 Old 10-22-2019, 05:40 AM
Quoted: 2 Post(s)
Deleted....... duplicate post
Last edited by LZU_camper; 10-22-2019 at 07:10 AM. Reason: Deleted. Accidentally duplicate post
LZU_camper is offline
