Symptoms of fuel bad fuel pump - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 25 Old 09-17-2019, 10:26 AM
UR2EZ's Avatar
Quoted: 69 Post(s)
Originally Posted by Bluwaterbrew84 View Post
Is the high pressure pump at the DFCM? If so that is the one he heard. Where is the low pressure pump located?
The one Larry described is your low pressure pump and it is mounted on the drivers side frame rail. That's the one that whines when you turn the key. It supplies the HPFP that supplies the injectors and so forth
Sent from my SM-G975U using Tapatalk
UR2EZ is offline
post #12 of 25 Old 09-17-2019, 10:30 AM Thread Starter
Quoted: 8 Post(s)
Sorry for all of the questions, but where is the high pressure pump? Can you usually here it?
Stock for now.
Bluwaterbrew84 is offline
post #13 of 25 Old 09-17-2019, 10:50 AM
jman37's Avatar
Quoted: 385 Post(s)
Garage
No, it's below the lower manifold in the engine.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #14 of 25 Old 09-17-2019, 01:12 PM Thread Starter
Quoted: 8 Post(s)
I went and purchased a scan tool. It is throwing code P062A.
Stock for now.
post #15 of 25 Old 09-17-2019, 01:15 PM
lowmpg's Avatar
Quoted: 113 Post(s)
Stand by my earlier post, change your fuel filter and tighten it.
https://youtu.be/ipmRgS4DcKA
The Resurrection
lowmpg is offline
post #16 of 25 Old 09-17-2019, 04:28 PM Thread Starter
Quoted: 8 Post(s)
Just changed the fuel filters because they needed it anyway.* Still no dice.
Stock for now.
post #17 of 25 Old 09-17-2019, 04:31 PM
lowmpg's Avatar
Quoted: 113 Post(s)
Make sure you tightened it correctly, make certain you have the green washer properly installed
The Resurrection
lowmpg is offline
post #18 of 25 Old 09-17-2019, 04:33 PM Thread Starter
Quoted: 8 Post(s)
Also after trying to crank a hand full of times and doing the ke on key off thing a couple of times I noticed the dash lights dimming the last time i tried to crank. Could it be a battery issue after all?
Stock for now.
post #19 of 25 Old 09-17-2019, 04:33 PM Thread Starter
Quoted: 8 Post(s)
Pretty confident that everything was done correctly.
Stock for now.
post #20 of 25 Old 09-19-2019, 08:16 AM
Quoted: 5 Post(s)
I know after changing fuel filters I usually cycle the fuel pump a good number of times to try and prime everything back up (I even pre-fill the oil filter from my 7.3 habits) and it cranks about .5 seconds longer than normal operation.
Does your scan tool have any datalog streaming? May be worth while to check some pressures to see if it's getting what it needs when cranking.
Also, newer vehicles hate sitting. I left mine sit for about a month and both batteries were dead (brought them back from 4V lol) and have been fine since. If I don't drive it at least once a week I'll let the remote start run for 15 minutes to keep her up and fresh. My 7.3 sits for much longer (and is a manual so not remoting it) but has some big Optima deep cycle batteries in place and those things are beasts (started at -30F, never plug it in, to see if it was not gelled or would warm up, gelled and died 30 seconds later, 6.7 was gelled and would not supply enough fuel past idle), they are way to tall for the 6.7 though
james2488 is offline
