Won't start after installing CP4 bypass - Page 2 - Ford Powerstroke Diesel Forum
 6Likes
post #11 of 11 Old 09-10-2019, 11:16 PM Thread Starter
broncobilly_69's Avatar
Quoted: 53 Post(s)
Originally Posted by rcg270 View Post
If you didn't run into issues, how long did it take you from start to finish?
The first time it probably took 5-6 hours. I'm pretty slow when it comes mechanical stuff and fussed around a bit with how I wanted the hose to run. Having an air ratchet, drill, or 1/4" impact helps a bit, especially with the plastic intake.
Some instructions say to grind some stuff off of the bottom of your lower, aluminum intake. I didn't need to and have plenty of clearance, so much that I can't see how it would be an issue.
I didn't remove my upper fuel filter, like I see some people doing. I did remove the hot side CAC pipe and completely take the bolts out of the plastic intake on it's rear, driver's side. They hang up and make removal difficult. you just have to pull up hard on them after they are unscrewed (easier said than done in tight quarters)
I had it down to about 2 hours by the third time, having my supply line cut already and my hose ran.
This video was quite helpful and the second one was good for removing the plastic intake.
bc_vickers likes this.
broncobilly_69 is offline
