Titan 65 gallon replacement fuel tank - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 30 Old 08-13-2019, 04:30 PM Thread Starter
palmeris's Avatar
Quoted: 9 Post(s)
Garage
just installed , dealer did it and set the program for 65 gallons. On first fill up showed 999 miles to empty, stayed there for the first 20 miles or so and is now showing 750 miles to empty and gauge is at 3/4 , Said it would take a few tanks to get the averages back in line but I love it so far.
Painted the straps with a rattle can of bed liner paint , didnt like the shinny look of the straps. some pics...
ID:	721749   Click image for larger version
ID:	721751   Click image for larger version
ID:	721753   Click image for larger version
HeavyAssault and john galt like this.
2014 F450 PLATINUM - 6.7 stock. Tow package, FX4 package, Weather Tec matts, Factory seat covers, Roll n Lock bed cover, sprayed on bed liner, Fox 2.0 I.F.P. adjustable shocks & steering stabilizer, S&B silicone body mounts, Titan 65 gallon XXL replacement tank, Dura Flap Customized Mud Flaps.....more to come
palmeris is offline
post #2 of 30 Old 08-13-2019, 04:36 PM
Quoted: 105 Post(s)
I love my 65 gallon tank. Have had it installed for over 5 years now. I get the 999 for like 250 miles before it starts to decrement. Usually the first 10 gallons used does not start the fuel gauge to decline. Pulling my 5th wheel, about 7.5k, i can go about 600 miles with ease.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 30 Old 08-13-2019, 04:54 PM Thread Starter
palmeris's Avatar
Quoted: 9 Post(s)
Garage
Yes im setting up the truck to be the tow machine it was designed to be.....plan is for a big heavy 5th wheel with garage for the Harley....retirement and traveling the country....long distance options are a must...also looking at the side kick style of aux tank , the 15 gallon ones that go up over the wheel well to carry some high test for the v-twin but not sure how to effect a nice clean way to, transfer to pump it into the bike...
beaureed445 likes this.
palmeris is offline
post #4 of 30 Old 08-13-2019, 05:18 PM
Quoted: 105 Post(s)
What ever transfer pump you decide, make sure it is gasoline compatible. Fil-Rite might have one. Most transfer pumps are for diesel and the seals aren't compatible with gasoline.
Also, not sure if gasoline "tanks" are DOT approved for enclosed areas of a trailer??? Your insurance company might not approve either.
Larry
post #5 of 30 Old 08-13-2019, 05:53 PM Thread Starter
palmeris's Avatar
Quoted: 9 Post(s)
Garage
The sidekick is an aux tank that goes in the bed of the truck, over the wheel well, its certified for fuel...
cant post a link to titans site but here a few photos
palmeris is offline
post #6 of 30 Old 08-13-2019, 06:35 PM
Quoted: 115 Post(s)
I think his insurance will be ok with that
Sent from my iPhone using Tapatalk Pro
Jav_eee is offline
post #7 of 30 Old 08-14-2019, 05:40 AM
Quoted: 105 Post(s)
Check the certification and make sure fuel includes gasoline.
Larry
post #8 of 30 Old 08-14-2019, 05:49 AM Thread Starter
palmeris's Avatar
Quoted: 9 Post(s)
Garage
DESCRIPTION
The TITAN™ Sidekick provides 15 gallons of handy storage and transport of flammable, combustible or nonflammable liquids. The Sidekick and its transfer accessories are compatible with Diesel Exhaust Fluid (DEF).
Constructed of military grade, cross-linked Polyethylene for tough good looks
Carry gasoline, diesel, kerosene or many other flammable, combustible or nonflammable fluids safely and securely
Mounting brackets are galvanized steel to beat corrosion, and powder coated to be attractive
Can be mounted on any corner of truck bed
Mounts over fenders out of the way
FREE 2 gpm Shaker Siphon included
Durable finish stays looking good
Super simple to install
Fits full-sized, mid-sized and some compact pickup trucks
Grounding kit included for safety
Meets Title 49 U.S. Federal Registry
Lifetime Warranty
palmeris is offline
post #9 of 30 Old 08-14-2019, 06:57 PM
Quoted: 46 Post(s)
Would be soo cool to have a 65 gallon Titan but good God almighty I'd hate to fill it all at once. I know it's all relevant but still.
2012 F250 Crew Lariat FX4
Stock? Sure, that's what we'll call it.
Grish76 is offline
post #10 of 30 Old 08-14-2019, 07:10 PM
Quoted: 105 Post(s)
DESCRIPTION
Lifetime Warranty
That is good it is ok for gasoline. Not many tanks seem to be ok for gas.
Yes, can require a couple or 3 swipes of the credit card or a trip inside to pay for a fill when the tank is close to empty.
you will be surprised how many people pass you more than twice when you are covering a long stretch of highway and that is even you making pit stops for the bathroom and fixing a sandwich if towing rv at the rest areas.
Larry
