No A/C..... - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Larry1013
post #1 of 9 Old 07-16-2019, 06:18 PM Thread Starter
outdoorsman75's Avatar
Quoted: 2 Post(s)
No A/C.....
So went to turn on the air the other day, and blowing straight heat. Tried to cycle a few times, no change. From what I gather, even though it's push button selection on dash, it's cable driven under dash. Anyone have any experience? Entire dash need to come out or can it be reached through access panels? Any help is greatly appreciated folks!!
outdoorsman75 is offline
post #2 of 9 Old 07-16-2019, 07:02 PM
Quoted: 105 Post(s)
Not aware of any "cable driven" doors or controls on the HVAC now days. Have you checked the freon level to see if low or if there is a leak? The evap core is known to develop leaks on these trucks.
What year is your truck?
kaya likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 9 Old 07-16-2019, 08:54 PM
Quoted: 695 Post(s)
Check to see if the ac clutch is cycling. If it is, you likely have a blend door issue.
If it isn't, there may be a clutch circuit issue, the clutch or compressor or the system is low.
As mentioned, evaporator cores are fairly common
The greater danger for most of us lies not in setting our aim too high and falling short; but in setting our aim too low, and achieving our mark.
-Michelangelo
kaya is offline
The Following 2 Users Say Thank You to kaya For This Useful Post:
outdoorsman75 (07-17-2019)
post #4 of 9 Old 07-17-2019, 10:56 AM
SmokeEater829's Avatar
Quoted: 9 Post(s)
Garage
Anyone had the evap core changed? About how much does that run? Iím about 98% sure thatís what my problem is.
Sent from my iPhone using Tapatalk
SmokeEater829 is offline
post #5 of 9 Old 07-17-2019, 11:50 AM
Quoted: 105 Post(s)
Evap core requires the dash to be pulled.
Larry
post #6 of 9 Old 07-17-2019, 12:20 PM
Drunk Post Extraordinair
Old King Coal's Avatar
Quoted: 231 Post(s)
Garage
Mine cost just shy of $1600. My defrost mode actuator was bad so it was replaced. I also had the blend door motors, recirculate motor and evap temp sensor replaced while they had it a part. It was $800 labor.
So strong is Tradition that later generations will dream of what they have never seen.
Old King Coal is offline
post #7 of 9 Old 07-17-2019, 05:36 PM Thread Starter
Quoted: 2 Post(s)
Larry,
It's a 2011 250 Lariat. I haven't checked levels as of yet, but kinda sounding like that should be my starting point!!
post #8 of 9 Old 07-17-2019, 06:30 PM
Quoted: 485 Post(s)
Garage
Question: You can push the function buttons and the air switches vents as you have commanded?
Choosing heat will cause the air to get hotter?
As @kaya mentioned, is the compressor clutch engaging(rotating)?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #9 of 9 Old 07-20-2019, 06:04 PM
I bought a borescope camera and could see my evaporator core quit. Did the repair myself. Parts cost $300 for Motorcraft. I was quoted $2100-$2400 for the repair so I did the work easily over two days and took it for a recharge the next morning. The $125 was included in the $300
Buffalohead is offline
