deleted with 50 gal tank question - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 11 Old 07-16-2019, 05:31 AM Thread Starter
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 593 Post(s)
Feedback Score: 11 reviews
for those of you running the bigger fuel tank that goes in the stock location and are deleted... does the truck lean to the drivers side?
im debating between the stock replacement and the inbed aux system.
i dont want to lose bed space (short bed) but i dont want the truck to lean neiter.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #2 of 11 Old 07-16-2019, 06:27 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 767 Post(s)
Feedback Score: 3 reviews
Yea...tough choice. That 50 gallons is like adding roughly 350lbs to the frame/driver's side. Might be noticeable at a full tank of fuel. Maybe not so much with 1/2 or less fuel in the tank.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 11 Old 07-16-2019, 06:27 AM
Treatcg's Avatar
Quoted: 61 Post(s)
Mine leans to driver side with stock tank. I have a 40 Donaldson in place of the stock setup.
Installing Carli Backcountry with full replacement leafs this weekend. Wonder how the 50 gallon would affect it?
Sent from my iPhone using Tapatalk
Treatcg is offline
post #4 of 11 Old 07-16-2019, 07:18 AM Thread Starter
BBBRRRRRTTTTT
Quoted: 593 Post(s)
i like that the inbed aux system puts the weight in the middle, will help smooth out bed hop, and is a few hundo cheaper.
wish it came with a 30+ gallon tank like my 6.0 did. i dont need THAT much fuel but 26 just isnt enough.
HeavyAssault likes this.
post #5 of 11 Old 07-16-2019, 09:35 AM
Phong6.7's Avatar
Quoted: 24 Post(s)
I have two deleted f250 ccsb with titan 50 gallon fuel tank in the stock location and it doesn't lean to the driver side but both truck is lifted 6in on 37s and they do have bigger coil and add a leaf.
Phong6.7 is offline
post #6 of 11 Old 07-22-2019, 09:12 PM
Does anyone know if a titan fuel tank for a short bed will fit a long bed truck? Wanting more range from my 16' F450 as it gets 8.8 mpg avg. I'm just curious if the short bed tank has better ground clearance as I'm in heavy construction/ oil field related sites regularly. I feel like 65gal is a tad overkill for my needs but factory is inadequate. TIA
Sent from my SM-G950U using Tapatalk
tcothran21 is offline
post #7 of 11 Old 07-23-2019, 01:33 AM
Quoted: 105 Post(s)
Diesel fuel weighs approx 7 pounds per gallon. Adding a 50 gallon tank will only add approx 175 and 200 pounds. Most drivers weigh this much or more. So,, adding the larger tank should not affect the stance of the truck when viewed in a static status. I do not notice any change in the static stance of my CCLB truck with the 65 gallon Titan tank.
Adding a 50 gallon tank to a LWB truck might be possible. Without a tank and test fitting, if would be impossible to know if the LWB fuel tank mounts would need to be relocated or you would need the SWB tank mounts. The next problem one might encounter is the location of the fuel pickup/float/fuel return. Woudl the fuel lines need modifications in length? Lastly would be the fuel tank fill hose. How close to the LWB location would it be or mods be needed?
hogbody and tcothran21 like this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #8 of 11 Old 07-24-2019, 11:07 AM
Loud Exhaust Aficionado
Timbo_Slice's Avatar
Quoted: 59 Post(s)
Garage
Titan makes a spare tire mount fuel tank also. I don't know if it is gravity fed or you need a transfer pump. Could be an option for you.
'15 F350 6.7L Super Crew Cab 4wd, 37 13.50 R20 Nitto Trail Grapplers on 20x12 TIS 535b -44 offset
Front - PMF 4-link 6 inch lift
Rear - PMF 2.5 Lift from Rear Shackle Hanger Flip Kit
- No name 5" rear block
Baja Customs Tracinator tracbar
AMDP pass through egr plate
AMDP Billet aluminum Y pipe intake
SCT TS+ Livewire
Full EGR, DPF, CCV delete
5" MBRP downpipe back straight pipe
Rigid D2 fog lights, 20" Opt7 light bar
Mag-Hytech high capacity lower oil pan
Mag-Hytech high capacity transmission pan
Redhead Steering Gear Box, Helwig sway bars
Eventually I'll get around to the JL Audio 13w2 install
Timbo_Slice is offline
post #9 of 11 Old 07-24-2019, 04:26 PM
hogbody's Avatar
Quoted: 77 Post(s)
Garage
If it leans you need new Springs. 300lbs of added weight will never be noticed.
hogbody is offline
post #10 of 11 Old 07-24-2019, 04:31 PM
hogbody's Avatar
Quoted: 77 Post(s)
Garage
S&B has a new 60g fuel tank . Still looking for more specs
hogbody is offline
