Tyrant tow tune boost - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 07-12-2019, 03:36 AM Thread Starter
Jstahley's Avatar
Quoted: 30 Post(s)
Ive got the tyrant tow tune and i dont think ive seen it go over 15 lbs of boost
Im woundering what you guys see with yours. I think stock i would see 20 on occasion. My 11 stright, pipe and egr fell off. With a s&b intake
Jstahley is offline
post #2 of 11 Old 07-12-2019, 04:34 AM
joebuck's Avatar
Quoted: 141 Post(s)
On my heavy tow tune from Tyrant Iíve seen in the 30s pulling some long step grades but Iím so running a 15+ turbo which can handle much higher boost than the 11-14 so yours may be turned down to save your turbo from over speeding? idk I would send them a message or data log and set it to them if your concerned, but if it pulls no problem and not getting hot I wouldnít worry about it
joebuck is offline
post #3 of 11 Old 07-12-2019, 12:00 PM
doczenith1's Avatar
Quoted: 15 Post(s)
Seems like I remember seeing around 20 just like stock when I was towing last weekend with the tow tune. I can confirm next weekend when I hook the camper up again. In fact I'll fire up Torque Pro and get a actual max boost reading.
doczenith1 is offline
post #4 of 11 Old 07-13-2019, 06:48 AM
joebuck's Avatar
Quoted: 141 Post(s)
Same here heading back home from camping with the 5er hooked up tomorrow so I will get some numbers as well as we pull some grades and report back
joebuck is offline
post #5 of 11 Old 07-13-2019, 08:45 AM
Quoted: 10 Post(s)
I'll occasional see 20 when towing up long wills or when passing under heavier throttle but it usually stays in the 10-15 range on flat ground and rolling hills on the interstate. I have a 15 and leave the tow tune installed 100% of the time. I like the way the truck performs with it.
druston is online now
post #6 of 11 Old 07-13-2019, 12:05 PM
Drunk Post Extraordinair
Old King Coal's Avatar
Quoted: 197 Post(s)
Garage
If I really get on mine it will do 20.
Free men must live simple lives and have simple pleasures.
Old King Coal is online now
post #7 of 11 Old 07-14-2019, 03:26 AM Thread Starter
Jstahley's Avatar
Quoted: 30 Post(s)
Next time i have the trailer on and im going up a good hill ill step on it real good. Im almost positive its the tune tho when in proformance caned tunes on the sct it would hit 20 lbs on 1/4 throttle
Jstahley is offline
post #8 of 11 Old 07-14-2019, 02:24 PM
joebuck's Avatar
Quoted: 141 Post(s)
So pulling onto the freeway a few different times coming home today I saw 32-34lb of boost at about 3/4 throttle pulling steep grades(not super long) would hold around 26/28, still had a ton to go if I needed but it seems to hit 30s no problem, like I said I have the 15+ turbo and supporting tunes so that could be it, yours being a 11-14 they couldíve held back to not oversleep the turbo, just a guess
joebuck is offline
post #9 of 11 Old 07-14-2019, 02:48 PM
Quoted: 197 Post(s)
Garage
Thatís what it is. Canned tunes are hard on things. Most of the turbo failures come from over speeding the ceramic bearings. The 15+ and steel bearing aftermarket replacements can handle higher speeds.
joebuck likes this.
post #10 of 11 Old 07-15-2019, 05:19 PM Thread Starter
Jstahley's Avatar
Quoted: 30 Post(s)
Guess i was wrong.. I was towing today so i gave 3/4 throttle going onto highway and it went stright to 20 and kept climbing from there to almost 30 when i let up.
Jstahley is offline
