AC - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Old King Coal
  • 1 Post By redxjer
post #1 of 10 Old 07-10-2019, 05:44 AM Thread Starter
AC
I seem to have found a issue with my AC. It works fine till the outside temperatures are in the 90s and then it does not work. I have refilled it, but that did not help.
Brian Arnold is offline
post #2 of 10 Old 07-10-2019, 05:52 AM
jman37's Avatar
Quoted: 385 Post(s)
Garage
Probably your fan. Can you hear it turning on?
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is online now
post #3 of 10 Old 07-10-2019, 05:54 AM
HyOctane23's Avatar
Quoted: 23 Post(s)
I have the same issue as well. It works fine until the temperatures gets to around 90 degrees or so. When moving, it works fine even in the hot weather but once I stop at a light or in traffic, it isn't nearly as cold and I can feel myself start to sweat! I had the dealer check the pressures and they're okay but I do need to be sure the fan is clicking on.
2015 Ford F-250 FX4 - The Daily Pig
2004 Ford SVT Lightning - The Good Weather Feeling
2012 BMW S1000RR - The Speed Demon
HyOctane23 is offline
post #4 of 10 Old 07-10-2019, 06:21 AM
jman37's Avatar
Quoted: 385 Post(s)
Garage
It's probably your fan. Your fan is the item that keeps the coolness circulating while stopped. So if it's 90+ and you're not getting cold while stopped, it's your fan..
post #5 of 10 Old 07-10-2019, 06:32 AM
HyOctane23's Avatar
Quoted: 23 Post(s)
Is that a common issue that it doesn't come on when the AC turns on? I've done a forced regeneration before with my FORscan and the fan definitely came on for that. The whole AC issue has really been an issue since I bought the truck brand new, hence why I had the dealer check it out.
post #6 of 10 Old 07-10-2019, 07:22 AM Thread Starter
by fan you mean the engine cooling fan, not the blower fan right. also it did not matter if i was driving at highway speed or stopped
post #7 of 10 Old 07-10-2019, 08:37 AM
jman37's Avatar
Quoted: 385 Post(s)
Garage
Not sure if they're separate for that, but to me your issue sounds like it's fan related. Fan should come on automatic with the AC on.
Your issue sounds like you have something else. Can you hear the clutch engage when it's on?
post #8 of 10 Old 07-10-2019, 10:42 AM
Quoted: 115 Post(s)
FWIW I donít hear the cooling fan any different than when the AC is off. Kind of a weird issues if the pressures are checking out to be ok. Iíd be more inclined to think itís an issue with the blend door.
Sent from my iPhone using Tapatalk Pro
Jav_eee is offline
post #9 of 10 Old 07-10-2019, 02:32 PM
Drunk Post Extraordinair
Old King Coal's Avatar
Quoted: 231 Post(s)
Garage
Just for the record, you will always hear the fan turning. These trucks have viscous fan clutches that will always turn, but when they go bad will not lock up like they are supposed to, which wonít give you enough air flow over the condenser.
So if itís a fan problem, itís the fan clutch.
HeavyAssault likes this.
So strong is Tradition that later generations will dream of what they have never seen.
Old King Coal is offline
post #10 of 10 Old 07-10-2019, 05:26 PM
Quoted: 27 Post(s)
Mine failed locked on. I just replaced it about a week or two ago. Realy an easy job. Remove shroud around fan. Loosen 4 bolts that hold fan on. Use air chisel to bust clutch nut loose, and spin it off. Reverse operation to install new one. Old clutch was ruining my mpg.
Old King Coal likes this.
redxjer is offline
