Rf tire wear - Ford Powerstroke Diesel Forum
 4Likes
  • 1 Post By SuperCrutyPS
  • 3 Post By Larry1013
post #1 of 8 Old 06-09-2019, 05:14 PM Thread Starter
jgrassano's Avatar
Rf tire wear
Getting baffled. I have been through 3 sets of tires numerous alignments. And having front end checked several times. I still get chopping on the rf tire outside edge. All other tires are wearing perfectly. Any thoughts.
Sent from my iPhone using Tapatalk
jgrassano is offline
post #2 of 8 Old 06-09-2019, 05:32 PM
SuperCrutyPS's Avatar
Quoted: 592 Post(s)
Garage
How is the shock on that corner? I had the RF tire doing that on my '01 - the guy @ my tire shop suggested shocks. I replaced all the shocks, the problem went away. Just a thought.
HeavyAssault likes this.
Darryl | Owner/Operator
Truck | 2001 F350 CCLB
5th Wheel |
Proud Veteran | US Navy - '76-'80 - Petty Officer 2nd Class (E5)
SuperCrutyPS is offline
post #3 of 8 Old 06-10-2019, 03:37 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 767 Post(s)
Feedback Score: 3 reviews
^^^^As above.
Pull off that shock and check it.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #4 of 8 Old 06-10-2019, 05:15 AM
Quoted: 105 Post(s)
I think the correct term is cupping....not chopping...
HeavyAssault, lowmpg and Hydro like this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #5 of 8 Old 06-10-2019, 02:58 PM Thread Starter
jgrassano's Avatar
Shocks are new within past six moths. I replaced them to try to fix this issue
post #6 of 8 Old 06-15-2019, 05:58 PM Thread Starter
jgrassano's Avatar
Anyone have any thoughts ??
post #7 of 8 Old 06-15-2019, 08:49 PM
Quoted: 318 Post(s)
Garage
Cupping is usually from out of balance and/or bad shocks -- have you checked that rim to see if it runs true? -- when the tire is balanced, does it need a lot of weight?
Run the truck along side a long line or crack in a parking lot -- try not to steer, get lined up before
now, measure the distance from the line or crack to the front and rear tire -- should be the same, other wise the truck is dog legged -- your alignment guy can fix that
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #8 of 8 Old 06-29-2019, 05:27 PM Thread Starter
jgrassano's Avatar
Ok I will check that thank you
