Oil full after 12 qts? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By HeavyAssault
post #1 of 4 Old 06-03-2019, 09:20 AM Thread Starter
cmunsell's Avatar
Quoted: 4 Post(s)
Just did an oil change on my '13 F250 yesterday (Valvoline PBX in 1 gallon jugs) - after letting everything drain for 20 minutes or so I refilled with 3 jugs and then checked. After only the 3 jugs (12 quarts unless common core math has changed that) my dipstick is reading smack in the middle of the fill range. Thought perhaps it just hadn't found its way into all the nooks so I let it run for a few minutes to circulate - after a little cool down it is still reading right in the middle of the range.
Is it possible there was enough residual oil left from the change to be 'full' after 12 quarts? Oil on the stick was still very clean/not sooty as if it had a large portion of old oil mixed in.
A little history to consider - after my last oil change with 13 quarts the dipstick was reading right at the top or a little over. I figured I did not let it drain enough or perhaps was a little heavy handed on the last required quart.
I do not want to run this engine low on oil - but I don't want too much either.
I guess my question is do i add the 13th quart knowing it will show a little high or leave it as is with the indicator right in the middle of the fill range?
cmunsell is offline
post #2 of 4 Old 06-03-2019, 09:26 AM
JustinOOO9's Avatar
Quoted: 1699 Post(s)
Garage
Feedback Score: 3 reviews
Check it after driving around for a bit and letting it sit over night. Does the dipstick say what amount to add when oil reaches add line? my 7.3 has a little "add line denotes 2 quarts low" but not all dipsticks say etc. Checking the owners manual will say too. I like to get mine to but not above the full line to see if it burns any between changes etc.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #3 of 4 Old 06-03-2019, 01:38 PM
rogersbonntr's Avatar
Quoted: 29 Post(s)
After changing my oil, I'm right in the middle of the dip stick. I just leave it at 12 qtrs. The book says 12, so I don't add more to top off dipstick.
1997 F350 XLT CC SRW w/ 460 sold
2012 F350 Lariat CC SRW w/ 6.7
rogersbonntr is offline
post #4 of 4 Old 06-04-2019, 02:50 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 940 Post(s)
Interesting...my Owner's Manual says 13qts with a filter.
lowmpg likes this.
Officially The Biggest Midget In The Game
HeavyAssault is offline
