bought truck with wireless airbags and no remote - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By cowboystyle
post #1 of 9 Old 05-20-2019, 04:16 PM Thread Starter
Quoted: 11 Post(s)
As stated, I bought a truck with wireless airbags and no remote. I did not know it had airbags and was not advertised to have them, but it does and I'm happy about it.
The problem is I called Ride-Rite to get a part number and they said my ECU was older and they don't have remotes for them. What now? What are your suggestions for options to make my airbags work?
1997 F250 4x4 ext cab 5spd
2015 F350 lariat fx4 cc drw
cowboystyle is offline
post #2 of 9 Old 05-20-2019, 05:03 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 572 Post(s)
Feedback Score: 11 reviews
Manually fill/empty them
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #3 of 9 Old 05-20-2019, 09:02 PM
Quoted: 7 Post(s)
Check out the Air Lift WirelessONE system. You can either get the 1st gen or the second gen. I think the 1st gen is discontinued, because I wrecked it and they couldn’t send me a new one on warranty, instead they sent me the 2nd gen for nothing. It has blue tooth you can run in on your phone as well if remote doesn’t work. You just hook it to existing air bag air lines.
Sent from my iPhone using Tapatalk
2011 F350 6.7l stock engine & trans
4" carli lift w/ 35X12.5 R18 AT tires
Bullydog Diesel DPF/EGR delete tuner
4" MBRP exhaust
Firestone airbags w/ Air Lift WirelessOne control
torawhide41 is offline
post #4 of 9 Old 05-20-2019, 09:59 PM
Quoted: 7 Post(s)
Sorry I had it in canadian so it probably seems like a fortune... For you mericans...
4" MBRP exhaust
The Following User Says Thank You to torawhide41 For This Useful Post:
cowboystyle (05-21-2019)
post #5 of 9 Old 05-21-2019, 08:31 AM Thread Starter
Quoted: 11 Post(s)
I've decided to piece together an analog system since I already have the compressor. I bought a switch with gauge, a relay harness, and the plumbing i need. fingers crossed I did enough research to make this work
beaureed445 likes this.
post #6 of 9 Old 05-21-2019, 10:32 PM
Quoted: 7 Post(s)
Well that work too then! good luck with the project! YouTube will get ya through it, not to worry!
...if you decide the wireless way, it really is f’n cool not having to run hoses and more wires in the cab!
4" MBRP exhaust
cowboystyle (05-22-2019)
post #7 of 9 Old 05-22-2019, 09:30 AM
Quoted: 325 Post(s)
You can purchase a new ECU and corresponding remote. But be warned....it'll set you back a pretty penny. The ECU for the F3 is like $425 and then the remote is $230.
I recently finished working with Firestone on a replacement ECU and remote as mine was being a PITA and erratic at best. Fortunately they covered it under warranty but my teeth about fell out when I saw the replacement prices.
2017 F350 DRW King Ranch FX4
Blue Jeans w/Caribou Accent
No mods...yet. Enjoying stock and full warranty!
2004 F350 6.0 - Traded 2/4/17 (Pity the fool who bought it)
jd4010 is offline
The Following 2 Users Say Thank You to jd4010 For This Useful Post:
post #8 of 9 Old 05-22-2019, 01:00 PM Thread Starter
Quoted: 11 Post(s)
If I could have just bought a remote I would have done that. For me, the gauge with switch is more reliable, I value that over newer technology.
jd4010 likes this.
post #9 of 9 Old 05-23-2019, 02:50 AM
Quoted: 325 Post(s)
There is definite truth to your reliability statement. I've had both the gauge and switch option (on my old 2004) and now the F3 in my 2017. The gauge/switch worked every time (super reliable). When I bought the 2017, I didn't want to drill and run wires and air lines into the cab so I went the F3 wireless route. I do like the wireless for convenience and ease/cleanliness of install. It works well too but sometime it doesn't respond (remote) very well. I think the response part is partly due to my mounting location.
jd4010 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
2018 Ford Powerstroke F350 Initial Review KevinLV General 6.7 Discussion (2017-2019) 14 09-05-2018 05:20 AM
F450 or airbags - What gives??? Crisco28 General 6.7 Discussion (2017-2019) 12 06-14-2017 09:59 AM
I need a value on my truck wizbangdoodle General 6.4L Discussion 14 02-27-2017 12:07 PM
