1600* EGT's and blowing black smoke - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By calewjohnson
post #1 of 6 Old 05-05-2019, 07:46 PM Thread Starter
broncobilly_69's Avatar
Quoted: 53 Post(s)
Pulling <9,000 lbs up not so steep grades at about 50 mph, I twice broke 1600 degrees pre turbo EGT's. It was still in 6th gear and and I check my side mirror and see a lot of black smoke coming out my tail pipe. Does this sound right? I know these things run a bit not, but holy smokes, 1600 degrees!
2015 CC, LB, 6.7, 4X4, DRW, Lariat ultimate, 160,000 mi. SCT Livewire w/ Tyrant tow tune. Deleted.
96 F250, 2wd regular cab. bone stock, 235,000 miles.
broncobilly_69 is offline
post #2 of 6 Old 05-06-2019, 01:51 AM
calewjohnson's Avatar
Quoted: 87 Post(s)
I have the same as you (no flat bed though).
I run a Tyrant tune...only the tune for Heavy Towing.
When I am not towing, I will get a puff of black smoke when passing someone (downshift from 6 to 5).
Surprisingly, when I am towing the Toy Hauler (20k lbs), I don’t think I’ve ever seen black smoke, even in a downshift to climb a hill.
Now, the temps. I am deleted also and have a temp probe installed for my CTS. When towing, I have an alarm set for 1200 degrees. Once it goes off, I back off and drive only by that temp probe (because I am not breaking any speed records). Once I am done with the climb, I go back to speedometer. I see no reason to destroy the truck trying to be the first one to the top of the hill.
Cale
UR2EZ likes this.
Cale
US Navy 1995-Present
2015 F-350 CCLB DRW, Lariat,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Metallic w/Black Leather Interior,
14,000 LB GVWR,
4x4,
4.30 Gears,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Upfitter Switches,
98 gallon Transfer Flow Bed Tank,
Timbrens,
10,150 lbs (CAT),
29,950 lbs with 2014 Voltage 3950 Toy Hauler (CAT).
calewjohnson is offline
The Following User Says Thank You to calewjohnson For This Useful Post:
broncobilly_69 (05-06-2019)
post #3 of 6 Old 05-06-2019, 03:57 PM Thread Starter
Quoted: 53 Post(s)
I was pulling less than 9,000 lbs. I wouldnít think she would even break a sweat under that load.
Iím wondering if the truck is not shifting as early as it should.
I was in tow/haul mode. Maybe an issue with my tune?
Sent from my iPhone using Tapatalk
post #4 of 6 Old 05-06-2019, 04:49 PM
ars5147's Avatar
Quoted: 211 Post(s)
Check your cold side CAC pipe, the known for blowing out while towing
1997 F350 CCLB 7.3
2019 F350 CCSB 6.7 Lariat Sport
ars5147 is offline
The Following User Says Thank You to ars5147 For This Useful Post:
post #5 of 6 Old 05-06-2019, 05:28 PM
Quoted: 87 Post(s)
Originally Posted by broncobilly_69 View Post
I was pulling less than 9,000 lbs. I wouldn’t think she would even break a sweat under that load.
I’m wondering if the truck is not shifting as early as it should.
Possibly. I had a tow tine from a another vendor and it was complete crap...even though everyone said it was great. I am told that each truck reacts differently to tunes...which is interesting.
I specifically talked to Tyrant, before you had to go through third party vendors. I stated what I was towing, I wanted exhaust brake to work overtime, no hair dryer sounds, etc. the tune they sent was awesome.
Cale
broncobilly_69 likes this.
Cale
14,000 LB GVWR,
4x4,
4.30 Gears,
Spray In Bed-Liner,
Camper Pkg.,
Upfitter Switches,
Timbrens,
10,150 lbs (CAT),
post #6 of 6 Old 05-07-2019, 06:47 AM Thread Starter
Quoted: 53 Post(s)
I went through a third party.
Iíll have to remember which 3rd party that was and give them a call.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Black smoke and lagging take off TheBaalmans 6.0 Motor problems 1 06-29-2018 05:24 PM
Why EGT's are so crucial. mschn99 General Diesel Discussion 11 06-05-2006 07:47 PM
