3.73 vs 3.55 - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By cowboystyle
  • 1 Post By Chuckfx4350
post #1 of 7 Old 04-20-2019, 07:42 AM Thread Starter
Quoted: 11 Post(s)
3.73 vs 3.55
I'm sure this has been covered several times, however searching has not satisfied my question. I currently have a 2015 with 3.73 and find that it seems to be perfect for me and what I do, pulling around 16k on a regular basis.
I've been looking at newer used trucks, 17+, and noticed a lot of them have 3.55. How big of a difference that will be?
1997 F250 4x4 ext cab 5spd
2015 F350 lariat fx4 cc drw
cowboystyle is offline
post #2 of 7 Old 04-20-2019, 08:00 AM
Quoted: 105 Post(s)
With the 6.7, you won't notice the difference unless you lift the truck and put huge tires on it.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 7 Old 04-20-2019, 11:59 AM
Quoted: 2 Post(s)
I have a 2016 with 3.55... tow a 16k 5th wheel all the time. Plenty of power.
honemch is offline
post #4 of 7 Old 04-20-2019, 03:17 PM Thread Starter
Quoted: 11 Post(s)
I didn't think there would be much difference, maybe a little lower RPM at highway speed? With the increase in HP between 15 and 17+ the low end is probably sufficient to get things rolling.
HeavyAssault likes this.
post #5 of 7 Old 04-22-2019, 04:13 AM
jman37's Avatar
Quoted: 254 Post(s)
Garage
You won't see a difference at all because they're so close together. If you went from a 3.55 to 4.10 then yes you would.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's
'88 Mustang LX - Built 306ci, built AOD, 4.10's
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #6 of 7 Old 04-28-2019, 04:25 PM
Quoted: 4 Post(s)
Even with a lift and larger tires the 6.7 moves it with no problem in 3:55s
Chuckfx4350 is offline
post #7 of 7 Old 04-29-2019, 04:35 AM
joebuck's Avatar
Quoted: 137 Post(s)
I have a 12 F350 with 3.55 gears and I have a 2.5 leveling kit and run 35s and can haul or 5er no problem, dont think the difference will be noticeable.
2012 F350 CCLB Lariat/ EZ Lynk Tyrant tuned/deleted/15+turbo swap/No limit stage 2 intake/H&S silicone CAC pipe/5 exhaust/2.5 BDS Leveling kit on 35s/Fox shocks/20 XD grenades
joebuck is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
3.55 or 4.10 texasvet General 6.7 Discussion (2017-2019) 32 06-30-2018 06:58 PM
3.31 or 3.55 gears on F350 Diesel Larry Mac General 6.7 Discussion (2017-2019) 26 02-19-2018 12:22 PM
3.73 vs 4.10 gearing for Transmission Longevity SouthFLDiesel 99-03 7.3L General Discussion 36 01-23-2018 12:19 PM
Pros and Cons for Axle Ratio... 3.55 or 3.31???? High7echRedneck General 6.7 Discussion (2017-2019) 17 12-16-2017 07:59 AM
3.55 vs. 3.73 tobyl18 General 6.7 Discussion (2017-2019) 23 07-31-2017 01:09 PM
