Factory Brakw Controller not working??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-18-2019, 01:27 PM Thread Starter
edreddy's Avatar
Quoted: 2 Post(s)
Garage
Ok, this is weird. I noticed last week that the integrated brake controller in my 2013 Lariat F-350 wasn’t sending any brake signal to my fifth wheel.
I even jacked up the gain to 10 and nothing. I am beginning to think that it has never worked properly from the start, as I always left my gain around 4 to 5 just as I had it on my 2011 F150.
My next step is to plug in my FORScan app to see if it’s throwing codes when I’m towing but I’m going to use the PC version.
Anyone else have this issue or know of any troubleshooting for it? So weird.
Ed
2013 Silver F-350 CREW 6.7L 4x4 Lariat. No mods. No delete. Just pure OEM until the warrant runs out.
edreddy is offline
post #2 of 7 Old 04-18-2019, 01:32 PM
Jstahley's Avatar
Quoted: 26 Post(s)
So when you slide the controller thers nothing. Does it say trailer is connected on dash when turned on. Have you checked fuses
Jstahley is offline
post #3 of 7 Old 04-18-2019, 05:12 PM
Quoted: 105 Post(s)
Does your trailer have auto adjusting brakes? Many of the trailers with drum brakes have to b manually adjusted.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #4 of 7 Old 04-18-2019, 05:28 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 558 Post(s)
Feedback Score: 11 reviews
If there are tbc faults they show on the LCD screen at start up.
As stated above, make sure you are getting the trailer connected alert and that the trailer is workimg proper
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #5 of 7 Old 04-19-2019, 08:46 PM Thread Starter
edreddy's Avatar
Quoted: 2 Post(s)
Garage
J- when I adjust gain with slider it has zero impact on the trailer brakes
Larry - no pretty basic electric brakes. And it’s a brand new trailer
Ps- yeah no faults. When I plug in a connector tester, the brake does not measure any input. So weird. Truck detects it. Powers the lights. But nothing to the brakes. How weird is that?
And it’s the OEM integrated brake controller.
Is it possible it’s just not working properly and not throw codes? Did the dealership not enable it correctly?
Thanks for your help guys.
Ed
edreddy is offline
post #6 of 7 Old 04-20-2019, 06:16 AM
joebuck's Avatar
Quoted: 136 Post(s)
Ed
Was this something you had added from a dealership? If not then maybe do some testing and have some one hook it up and hit the brakes maybe follow the lines back from the plug to your trailer with a tick tracer and see if your dropping voltage somewhere or maybe it’s not sending it at all coming out of the plug??
If you had it added then take it back and make them fix it. That’s where I would start
2012 F350 CCLB Lariat/ EZ Lynk Tyrant tuned/deleted/15+turbo swap/No limit stage 2 intake/H&S silicone CAC pipe/5” exhaust/2.5” BDS Leveling kit on 35s/Fox shocks/20” XD grenades
joebuck is offline
post #7 of 7 Old 04-20-2019, 06:19 PM
BBBRRRRRTTTTT
Quoted: 558 Post(s)
If your under warranty let the dealer fix it.
If not, do you have a friend with a 11-16 tbc? Make sure you have the harness and all that and not just the controller.
Have someone else with any controller hook up to your trailer to verify the trailer.
Similar Threads
Thread Thread Starter Forum Replies Last Post
2005 factory trailer brake controller wiring (factory) cingularchris 6.0L Electronics Discussion 0 04-05-2019 05:36 PM
Adding factory brake controller 68rustbucket 6.7 Electronics Discussion (2017-2019) 2 04-03-2019 04:46 PM
05 f350 factory heated mirros not working jamesw343 6.0L Exterior Discussion 6 01-03-2019 12:33 PM
06 Upfitter Switches & Factory Brake Controller In A 2002 ? doubleslottedflaps 99-03 7.3L General Discussion 5 11-06-2018 06:10 PM
Adding factory brake controller for mt 05 f550. gtmustang00 General 6.0L Discussion 1 04-13-2017 11:38 AM
