What oil are you guys running - Page 2 - Ford Powerstroke Diesel Forum
 20Likes
post #11 of 42 Old 04-19-2019, 04:53 PM
calewjohnson's Avatar
Quoted: 83 Post(s)
I have run 5W-40 since the day I bought mine. Changed every 5k miles. Used Rotella for the most part until 35000, then Valvoline PBX ever since. I just finished my 95k service.
I have contemplated using Triax Fleet Supreme ESP 5W-40, Class 8 trucks go 80k on oil drains. If I did this, I would go 10k on oil changes with an analysis.
Thoughts??
Cale
HeavyAssault likes this.
Cale
US Navy 1995-Present
2015 F-350 CCLB DRW, Lariat,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Metallic w/Black Leather Interior,
14,000 LB GVWR,
4x4,
4.30 Gears,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Upfitter Switches,
98 gallon Transfer Flow Bed Tank,
Timbrens,
10,150 lbs (CAT),
29,950 lbs with 2014 Voltage 3950 Toy Hauler (CAT).
calewjohnson is offline
post #12 of 42 Old 04-19-2019, 06:09 PM
Quoted: 6 Post(s)
Just changed it at the Ford dealer and they put in 15-40. This is in CA where temp doesn't get lower that 50 degrees or so. Who am I to argue?
JSolve is offline
post #13 of 42 Old 04-19-2019, 06:53 PM Thread Starter
Jstahley's Avatar
Quoted: 30 Post(s)
Ya i said it backwards 15w40 summer and 5 40 winter
Jstahley is offline
post #14 of 42 Old 04-19-2019, 06:59 PM Thread Starter
Jstahley's Avatar
Quoted: 30 Post(s)
I used triax in my 6.0 and it loved it. I got oa a few times but never went more than 7k on a change.
I read on triax website that 6.7 get 1 to 2 mpg more with their oil. Im going to try n see and ill report back. I never get over 14.8 towing and 18.9 highway un loaded
Jstahley is offline
post #15 of 42 Old 04-20-2019, 10:33 PM
RandomForumGuy's Avatar
Quoted: 212 Post(s)
Garage
Originally Posted by JustinOOO9 View Post
Think I should tell everyone the secret?
"Cough, cough" running straight Archoil....
you found the trifecta because every oil change you can use it for your boomsticks now too. Billy mayes would be all over this. :https://www.archoil.com/products/ar4400-firearms-oil
RandomForumGuy is offline
post #16 of 42 Old 04-24-2019, 11:41 AM
doczenith1's Avatar
Quoted: 15 Post(s)
Mobil 1 Turbo Diesel Truck 5W-40 since the third oil change. Ford filter. Local Meijer sells the Mobil 1 for $25 a gallon.
doczenith1 is offline
post #17 of 42 Old 04-24-2019, 03:44 PM
Quoted: 17 Post(s)
I use Mobil 5W40 with Donaldson or Wix X filters. Change oil when minder goes off, usually around 10,000 miles. No problems. Any synthetic will give better protection than standard oil. I'll let you know how the oil sample comes back. I use synthetic in everything I own (vehicles, skid steer, garden tractor, lawn mowers, tiller etc). Never had an oil related failure using synthetic and it holds up better especially on air cooled engines. As long as it meets the manufacturer's specs, you should be good. More important than brand that it meets the manufacturer's specs.
thekroog is offline
post #18 of 42 Old 04-24-2019, 04:27 PM
zutmeloda2003's Avatar
Quoted: 5 Post(s)
Rotella 5w-40 with wix filter.
Stocked up last year with their mail in rebate.
zutmeloda2003 is offline
post #19 of 42 Old 04-24-2019, 10:12 PM
do not use mobil 1 TBT
I also used mobil 1 TBT until ford announced their new oil standard due to excessive wear. mobil 1 tbt does not meet ford oil spec WSS-M2C171-F1. I checked the bottles and even called mobil 1 tech support to ask.
After finding out I tried red line diesel truck oil but it is too expensive. Now I buy amsoil 15w-40 signature diesel truck oil with their preferred buyer program pricing.
Used to buy motorcraft filters but switched to napa platinum a few years ago.
olivebranch2006 is offline
post #20 of 42 Old 04-25-2019, 02:11 AM
ars5147's Avatar
Quoted: 208 Post(s)
What did they say?
Ive been wondering why their TD truck wont meet the spec.
ars5147 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
7.3 missing and running ruff Cowherdboy General Diesel Discussion 8 09-28-2018 11:00 PM
New ROF-T Running Boards by Romik for your Ford + Video Review CARiD CARiD.com 0 07-17-2018 03:15 AM
2008 F-250 Running Terrible, White Smoke, Searched Hundreds of Threds 5bradpeterson28 6.4 Motor Problems 3 05-01-2018 06:30 PM
Brand New Power Steps by Aries and Classic Running Boards for Ford F-Series CARiD CARiD.com 0 03-07-2018 04:17 AM
95 idling and running rough Bull 94-98 7.3 Motor Problems 15 10-31-2006 09:56 AM
