Cold side pipe - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 14 Old 04-03-2019, 01:37 AM
Quoted: 105 Post(s)
Originally Posted by redxjer View Post
I blew mine on a return trip from Denver to Houston pulling a necker. Rigged it up to limp home with a hose clamp. Later I bought a heavy duty hose clamp (constant tension clamp?) and it's been okay since. I'll replace them both one day.
Hot side does not give problems. It is already made of metal. Only the cold side is the major problem. I have only seen one hot side boot issue in the last 3 years on another forum of the 5 i visit regularly.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #12 of 14 Old 04-04-2019, 05:55 PM Thread Starter
roverjosh's Avatar
Quoted: 43 Post(s)
Garage
Originally Posted by tomshep View Post
Rudy's for $150 off of ebay.
They do fail and it will likely go sooner or later.
The question is, is it worth blowing that pipe out of town?
Cheap insurance and about an hours work.
Tom
So I found this one on fleabay for $99!
https://rover.ebay.com/rover/0/0/0?m...2F173157893477
Thoughts?
When it comes to mechanics, everything I know is from either breaking it or watching someone else do the same. Then I had to fix it....Is that bad?
Murphy's Law: "things will go wrong in any given situation, if you give them a chance."
roverjosh is offline
post #13 of 14 Old 04-04-2019, 06:04 PM
Quoted: 105 Post(s)
Thoughts?
Prices have come down since I bought my two piece metal for $150. This kit is probably pretty decent and functional. The lower metal pipe is not replaced with a silicone piece.
This is the same as the listing you have but about $30 cheaper.
https://www.ebay.com/itm/Cold-Side-I...L/352574198043
Larry
post #14 of 14 Old 05-03-2019, 08:48 AM Thread Starter
roverjosh's Avatar
Quoted: 43 Post(s)
Garage
So I was adding the washer fluid the other day and decided to poke around in the old Engine Bay. I still don't recognize half the s#!t in there.
Low and behold, the P.O. has already added a cold Side Pipe replacement. I will get some pics, as I can't tell the brand but it looks nice.
That just saved me $100 + bucks!
joebuck likes this.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help with exhaust leak - what is the Y pipe, up pipe, EGR pipe? alex1118 General 6.0L Discussion 2 12-02-2018 04:21 PM
H&S cold side pipe tuning required Treatcg 6.7 Performance Parts Discussion (2011-2016) 2 12-02-2018 12:17 PM
chineese cold side intercooler pipe Scerb 6.7 Performance Parts Discussion (2011-2016) 15 10-10-2018 03:26 AM
Hot Side Pipe beaureed445 6.7 Performance Parts Discussion (2011-2016) 3 12-11-2017 11:24 AM
Found Something When Installing Cold Side Pipe louisianashooter 6.7 Performance Parts Discussion (2011-2016) 5 12-07-2017 02:14 PM
