TBC setup question - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By powerstrokeshellback
  • 1 Post By TeddyD
post #1 of 9 Old 02-04-2019, 12:41 PM Thread Starter
rathail's Avatar
Garage
TBC setup question
Just bought a new TT, about 5800LB towing home from dealer.
Empty with full propane and a little water.
I verified the trailer brakes worked with the squeeze of the TBC.
Okay as I write this I'm getting a personal head slap, so could I just get some
confirmation of thought? I will be going through a full Manual process setup on
our first loaded trip to the coast.
The front brakes where overheating.
Had the gain at 5.5, I'm guessing that is too low and the front where working too hard?
It was stop and go city driving only about 9 miles.
2015 F350 6.7 CSB.
rathail is offline
post #2 of 9 Old 02-04-2019, 12:51 PM
Quoted: 115 Post(s)
How do you know they were overheating?
Bump up that gain. Iíd start at 10 and work your way down. Thatís just me though.
Sent from my iPhone using Tapatalk Pro
Jav_eee is offline
The Following 2 Users Say Thank You to Jav_eee For This Useful Post:
rathail (02-05-2019)
post #3 of 9 Old 02-04-2019, 01:33 PM Thread Starter
rathail's Avatar
Garage
Got a wiff of hot brakes on the way home and they were 121 degrees when I got my laser reader out at home.
Actually not sure if 121 is too hot, but is was a couple of minutes before reading them, it was more the smell.
rathail is offline
post #4 of 9 Old 02-04-2019, 05:01 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 609 Post(s)
Feedback Score: 11 reviews
Fords tbc is weak. Start high and work your way down until you aren't locking up your trailer brakes.
HeavyAssault likes this.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
The Following 2 Users Say Thank You to powerstrokeshellback For This Useful Post:
post #5 of 9 Old 02-04-2019, 08:38 PM
Quoted: 46 Post(s)
To test the trailer brakes and adjust the gain properly, at the beginning of your trip, while you are moving about 7mph, adjust your gain to 5. Slide the brake controller and if your brakes lock up, lower the gain until the trailer brakes bring your truck to a slow gradual stop. If the trailer brakes will not bring you to a gradually stop then adjust the gain higher until it does. My 13000lb trailer is not always at the same gain when I pull. I do this procedure every time I start a trip. The brakes should only assist your stopping ability, not control it. Also, and this is very important, if you are going down a hill and you feel the trailer pushing you or the rear of the trailer starting to swing out, DO NOT hit your foot brake pedal. This will cause a catastrophic towing fail. Just very lightly apply the trailer brake controller and speed up using the accelerator pedal. That will bring the trailer back behind you and you should be able to regain control. If you try to brake using the truck brakes, just wave bye to your trailer as it passes you and you both go for a roll.
TeddyD is offline
The Following User Says Thank You to TeddyD For This Useful Post:
post #6 of 9 Old 02-05-2019, 02:52 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 926 Post(s)
Feedback Score: 3 reviews
^^^^^ Follow the above posts @TeddyD , @powerstrokeshellback , and @Jav_eee got you covered.
Officially The Biggest Midget In The Game
HeavyAssault is offline
The Following 2 Users Say Thank You to HeavyAssault For This Useful Post:
post #7 of 9 Old 02-05-2019, 07:53 AM Thread Starter
rathail's Avatar
Garage
Thanks all!
I will have the wife reinforce this info on each trip::
rathail is offline
post #8 of 9 Old 02-05-2019, 09:21 AM Thread Starter
rathail's Avatar
Garage
As for the weak TBC on Fords. Does that apply to any other controllers on my truck?
I have a Prodigy 2 controller I used on my Taco and Explorer.
I would only try it if I have issues with factory setup.
rathail is offline
post #9 of 9 Old 02-05-2019, 09:36 AM
Quoted: 115 Post(s)
Iíve never felt my BC was weak. If I press the brake pedal like I need to stop in a hurry, it stops in a hurry. Watch the output meter on the dash, it varies by pedal pressure. Step on that brake like you mean it and your trailer should stop just fine, assuming itís brake system is good to go.
Jav_eee is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dual Battery Setup Question starnes General 6.7 Discussion (2017-2019) 34 12-07-2018 07:24 PM
Question about EZ Lynk operation t.i.p. 6.7 Performance Parts Discussion (2011-2016) 13 01-31-2018 06:26 AM
6.0 Coolant question? FICM question? GasGrassOrAss General 6.0L Discussion 12 01-25-2018 03:41 PM
4x4 functions question zemuron99 General 6.7 Discussion (2017-2019) 13 03-19-2017 10:12 AM
New turbo setup review (it's about time) Austen 99-03 7.3L General Discussion 13 02-12-2017 01:35 AM
