Trans flush - the dealership said do not do it. - Page 4 - Ford Powerstroke Diesel Forum
 12Likes
post #31 of 36 Old 07-01-2019, 04:26 AM
The Evil Twin's Avatar
Quoted: 173 Post(s)
Originally Posted by roverjosh View Post
I found something disturbing in the trans pan when I took it out. I found 9 small 1/4" (maybe) long roller bearings stuck to the magnet. That can't be good...
I can say that transmission has worked great while I've had it. 7k miles and nothing but smooth shifts and great performance.
Im getting nervous. I have my big trip cross country on Wednesday. I have to tow my stuff and my little VW from Omaha to Virginia Beach, via Tennessee. What would you guys suggest as far as road side assistance?
I wasn't worried at all about this trip until I dropped that pan....
Is there a dealer, or a Powerstroke shop up there that you trust? I would take them up and explain how you found them. Maybe gain some insight. They typically don't put extra bearings in there.
Have you had the truck from day 1? If not, it is possible that the PO had work done in it and those little pieces are left over.
As far as roadside? I'm an AMA member so use their coverage. Only called once when the RV blew a tire, but it worked out well.
HeavyAssault likes this.
2015 Oil Burner
CCLB Lariat Ultimate, 10k, Plow Package.
Mods have begun: 2wd Valance, Bully Dog GT, smoked lenses
The Evil Twin is offline
post #32 of 36 Old 07-01-2019, 09:26 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 928 Post(s)
Feedback Score: 3 reviews
If the last 7k have seemed fine...sounds like previous transmission work left you a few "Easter eggs".
Have you pulled an OASIS report to see what might have been done at a dealer? Are you running I40??
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #33 of 36 Old 07-01-2019, 10:18 AM
roverjosh's Avatar
Quoted: 51 Post(s)
Garage
Heavy Assault and Evil Twin, I am not the Original owner. I bought it with 164k in the clock. It’s shifted great since I got it.
I did pull the oasis report before I bought it and there was no history of tranny work. Not sure what’s going on there. When I was underneath it didn’t “look” like anyone had every pulled that transmission but that doesn’t mean anything.
I’m going with the “it works fine, don’t stress it” approach and get good road side service for now. Hopefully I reach VA in one piece and the. I can find a good diesel/tranny shop down there and get it looked at.
Of course, it it makes it there no problem... I may just not worry about it. I may just go find a used one at the junk yard and have it built up. The just swap it for comforts sake.
When it comes to mechanics, everything I know is from either breaking it or watching someone else do the same. Then I had to fix it....Is that bad?
Murphy's Law: "things will go wrong in any given situation, if you give them a chance."
roverjosh is offline
post #34 of 36 Old 07-01-2019, 01:00 PM
ZMANN's Avatar
Quoted: 4014 Post(s)
For the skeptics on service history - I wouldn't do a hot flush but drain the pan and refill which replaces a good bit of fluid, or as others have done (the more expensive way) drain, refill, drive, drain again, refill - which will replace most of the used oil.
whats the difference between this and a hotflush other than you do not get all the fluid ?
as soon as you drive the truck the fluid heats up and is the exact ( EXACT ) same thing as a hot flush
hot flush at ford = remove old hot fluid /fill with new hot fluid at the same rate
reason for it being hot = keep the cooling circuit open to let the fluid flow in and out at full rate
6.0 flush pdf
ZMANN is online now
post #35 of 36 Old 07-05-2019, 10:50 AM
Corey@CNCFAB's Avatar
Quoted: 1460 Post(s)
Feedback Score: 4 reviews
So I did the drain, filter replacement and refill. I DID reuse the gasket. It looks to be a reusable one.
And The "hobby Shop" is one of the DIY garages. Most every Military base has one for the service members to use to save money on car repairs.
Brakes went easy, filter change and refill went easy but I found something disturbing in the trans pan when I took it out. I found 9 small 1/4" (maybe) long roller bearings stuck to the magnet. That can't be good...
Did you happen to take a picture of the bearings? Chances are its a thrust bearing that is now missing a few rollers.
FYI, these are now on the website.
https://cncfab.us/i-30498955-a-1-tra...6r140-sbp.html
Just waiting on pics to get the other one up on there.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #36 of 36 Old 07-05-2019, 06:37 PM
roverjosh's Avatar
Quoted: 51 Post(s)
Garage
I thought I took a picture but it appears I didn’t. I have them in my box of goodies but I’m mid-move.
On a positive note, the drive from Omaha to Nashville was smooth as butter and totally uneventful. I averaged 13.5 almost 14mpg carrying a total of 14440 lbs with the trailer.
I haven’t ever towed a long distance or with any weight but the truck just cruises!!! I loved it. If was very sure footed and extremely easy to drove even with a load. Even with the bearing scare I am still very impressed and satisfied with my truck.
I will take pictures and post them when we get to Virginia Beach. We make the Nashville/Va Beach drive tomorrow at 6:30 am. Should take about 11 hours.
Thanks everyone for the comments!
On the road again!
