Will rear bumper flush mount flood lights interfere with parking sensors ? - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 14 Old 12-19-2018, 07:40 AM
The Evil Twin's Avatar
Quoted: 154 Post(s)
Thank you @Ragecajun !
The Evil Twin is offline
post #12 of 14 Old 01-14-2019, 09:58 AM Thread Starter
ROCKET VAPOR's Avatar
Quoted: 19 Post(s)
I can report no interference with rear bumper parking sensors when flush mounting Rigid 2x2 scene lights.
However, there is about 1/8" gap between the bumper and the top and bottom of the lights since there is no flat spot on the rear bumper.
ID:	713283   Click image for larger version
ID:	713285   Click image for larger version
ID:	713287   Click image for larger version
ROCKET VAPOR is offline
post #13 of 14 Old 01-14-2019, 10:04 AM
Loud Exhaust Aficionado
Timbo_Slice's Avatar
Quoted: 59 Post(s)
Garage
Nice. Could you cut out some sort of rubber or foam gasket to go behind the light?
'15 F350 6.7L Super Crew Cab 4wd, 37 13.50 R20 Nitto Trail Grapplers on 20x12 TIS 535b -44 offset
Front - PMF 4-link 6 inch lift
Rear - PMF 2.5 Lift from Rear Shackle Hanger Flip Kit
- No name 5" rear block
Baja Customs Tracinator tracbar
AMDP pass through egr plate
AMDP Billet aluminum Y pipe intake
SCT TS+ Livewire
Full EGR, DPF, CCV delete
5" MBRP downpipe back straight pipe
Rigid D2 fog lights, 20" Opt7 light bar
Mag-Hytech high capacity lower oil pan
Mag-Hytech high capacity transmission pan
Redhead Steering Gear Box, Helwig sway bars
Eventually I'll get around to the JL Audio 13w2 install
Timbo_Slice is offline
The Following 2 Users Say Thank You to Timbo_Slice For This Useful Post:
ROCKET VAPOR (01-15-2019)
post #14 of 14 Old 01-15-2019, 10:00 AM Thread Starter
Quoted: 19 Post(s)
The flush mount Rigid scene lights ( P/N 681523 ) came with a rubber mounting gasket.
However, I may try your idea with a thicker black sponge gasket material to fill the voids.
