6.7 high miles - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 13 Old 09-20-2018, 08:44 AM Thread Starter
6.7 high miles
Im looking at purchasing a 6.7. Curious to find out if anyone would be afraid of a 2011 6.7 with 234,000 miles. Has had Regular maintenance. EGR delete
Thays14 is offline
post #2 of 13 Old 09-20-2018, 12:30 PM
Six0~Stroker's Avatar
Quoted: 673 Post(s)
Feedback Score: 5 reviews
Idk. I would stay away from 2011 year trucks. Seems like they were hit and miss with major engine issues.
Sent from my iPhone using Tapatalk
White_Buffalo7.3 likes this.
2013 F-250 Lariat
Completely stock
Six0~Stroker is offline
post #3 of 13 Old 09-20-2018, 01:23 PM
v8deuce's Avatar
Quoted: 46 Post(s)
I know they had bad turbo's but with that milage it must have been changed by now.How is the rest of it, body,driveline,suspension? I wouldn't be afraid of it but it would have to be a good deal. Just my 2 cents worth.
Randy
It's better to remain silent and thought a fool than speak up and remove all doubt! (Abe Lincoln)
v8deuce is offline
post #4 of 13 Old 09-20-2018, 01:48 PM
Quoted: 673 Post(s)
Itís wasnít jus the turbo on the 2011. It was something major with the pistons/block.
Complete engine failure.
I think the general ratio was 50/50 so Iím not saying all of them were bad. Just something to watch out for and make sure you get a good deal knowing that might happen to you.
2013 F-250 Lariat
Completely stock
post #5 of 13 Old 09-20-2018, 02:48 PM
Quoted: 77 Post(s)
You asked, I'll answer, I wouldn't touch it. Then again, it all boils down to how much $$$$ you have to spend and if it's the only truck in your $$$ range that will meet your needs.
witness is offline
post #6 of 13 Old 09-20-2018, 03:15 PM
sierracharlie338's Avatar
Quoted: 72 Post(s)
Garage
Yep this right here. Just happened to my brothers 11. Engine replacement was north of 12k, not sure on final number though.
15 F250 CCSB Lariat 4WD white/caribou
Tyrant Pack, No Limit plates, MPD cold side pipe, ReadyLift SST 2.5 kit, Fox Shocks, S&B CAI, 295/65r20 Ridge Grapplers
Previous:
99 F250 SCLB 4WD
sierracharlie338 is offline
post #7 of 13 Old 09-20-2018, 03:17 PM
Quoted: 209 Post(s)
There were three common issues with early 11 trucks.
-Transmission valve body causing delayed engagement and erratic low speed shifting
-turbo failure partly due to bearing material and mostly due to early tuning overspeeding them
-a metallurgical issue with valve hardening causing exhaust valve to break apart and thus destroy the motor. (This problem seems to be limited to trucks buikt prior to April 2011)
Only other differences were the newer seats and dash in the 13+ trucks, and the bigger turbo and fuel pump in the 15+ trucks.
By no means was it 50/50 on engine failures.
Any issues you may run into at those miles are problems you would have with any truck.
If you are comfortable with it and the price is right-go for it.
Sent from my SM-G955W using Tapatalk
v8deuce likes this.
SOOTIE is offline
post #8 of 13 Old 09-21-2018, 03:42 AM
Quoted: 13 Post(s)
I personally purchased a 2011 CCSB 6.7 with 125K on it in December. I have done an EGR Delete, Exhaust, run it on tow tune daily. I have 180K as of this morning. I will be looking into changing the turbo shortly as the records do not show it as complete. I have heard about the head issues, but IIRC that was limited to cab/chassis models. I like the truck so far and it seems to have a good record. For the record...I hate Fords...but I'd rather have a reliable truck than a Chevy...
2011 Ford F-250 XLT Lariat Crew Cab FX4 6.7 L Powerstroke Diesel
boardboy330 is offline
post #9 of 13 Old 09-21-2018, 06:02 AM
jman37's Avatar
Quoted: 376 Post(s)
Garage
Don't be deterred by what others say. If you like it, runs good, has a maintenance history and the price is right go for it. Just because certain years had issues doesn't mean you'll have them. People who have '15's and even '17's have needed to replace major things already. It can happen to ANY year truck.
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is offline
post #10 of 13 Old 09-21-2018, 06:40 AM
White_Buffalo7.3's Avatar
Quoted: 191 Post(s)
Garage
I would say the 6.7 as a whole is pretty good.
2015 645k
2017 currently going towards 375k
Page 3 is where you want to read
180/30s,KC38R, CNC Fab Stg 2 HPOP, Sump, Walbro, Donaldson 6637, Leveled, 4'' straight to 7'' tip, 08 mirrors, 6.0 front end ect...
White_Buffalo7.3 is offline
