F-350 6.7 drivetrain maintenance - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By ACAMS
post #1 of 4 Old 08-09-2018, 05:33 PM Thread Starter
ACAMS's Avatar
I just bought a 2014 F-350 Platinum 6.7 diesel with the single rear tire and it is my first diesel.
What should be done maintenance wise ..... how often do I change the oil and what about the fuel filter?
It is 4x4 .... is there anything I need to do on a regular basis?
THANKS FOR ANY TIPS!
HeavyAssault likes this.
2014 single wheel F-350 Platinum 6.7 diesel
ACAMS is offline
post #2 of 4 Old 08-09-2018, 06:30 PM
Quoted: 105 Post(s)
Did it come with an owner's manual and diesel supplemental manual? Those will give you the basics of when to change oil, filters and servicing other areas. If you do not have a copy, you can download them here.
https://owner.ford.com/tools/account...h-results.html
Also, i would create an account on the Ford owner's site. It can give you info about recalls or field service actions or other items.
https://owner.ford.com/tools/account/sign-in.html
You can also down load the Ford App FordPass. It has an abbreviated OASIS report of work/maintenance performed by a Ford dealer.
Some people still change oil at 5K intervals and other let the intelligent oil life monitor tell them when a change is due. Now days most all CK-4 oils are approved for use by Ford. You can check here to see if an oil is approved or not on the Ford WSS-M2C171-F1...
https://www.fcsdchemicalsandlubrican...Motor%20Oil%5D
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #3 of 4 Old 08-09-2018, 09:49 PM Thread Starter
ACAMS's Avatar
Thanks ..... I don't remember seeing them.
I registered at the Ford owners link too!
ACAMS is offline
post #4 of 4 Old 08-10-2018, 02:03 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 920 Post(s)
Feedback Score: 3 reviews
Oil/oil filter changes along with fuel filter changes are the most frequent things you will do.
Officially The Biggest Midget In The Game
HeavyAssault is offline
