Rapid Heat Question - Page 2 - Ford Powerstroke Diesel Forum
 8Likes
post #11 of 19 Old 01-08-2017, 05:43 AM
Ranzan's Avatar
Quoted: 24 Post(s)
the truck doesn't warm up faster the cab does.... not a lot but it does
HeavyAssault likes this.
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #12 of 19 Old 01-08-2017, 06:23 AM
djmaguire's Avatar
Quoted: 1589 Post(s)
Garage
I'm thinking that not much in Regina warms up a lot in the winter. Lol.
I've seen the confusion about Rapid Heat before. For those unclear... the Rapid Heat option installs electric heating elements - think hair dryer - in the heater ducts. When the truck is started - and before the coolant flowing through the heater core is hot - the electric heating elements heat the air blowing into the cab. So... think expensive hair dryer.
My personal tendency is to rely on a block heater to warm things up quickly. A diesel-powered coolant heater would be the best, in my view. Those two options at least reduce wear on the engine. Rapid Heat probably goes the other way.
HeavyAssault and Ranzan like this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #13 of 19 Old 01-08-2017, 06:57 AM
Ranzan's Avatar
Quoted: 24 Post(s)
LMAO.... -35 with wind chills in the -40s.. but our igloos keep us warm
Azrael15 likes this.
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #14 of 19 Old 01-08-2017, 06:59 AM
djmaguire's Avatar
Garage
Holy crap! I don't even want those temps on the same planet with me! Be safe!
2004 F550 CC Lariat
post #15 of 19 Old 01-08-2017, 07:53 AM
ekimv65's Avatar
Quoted: 69 Post(s)
We've got the same problem in WI, brutal, but the big rig keeps rolling!
Sent from my iPhone using Tapatalk
ekimv65 is offline
post #16 of 19 Old 01-08-2017, 08:31 AM
I had the same question when purchasing my truck. Record lows in Atlanta last night. Here is what I captured warming the truck up this morning.
1 Minute run time. 50.5 F Outside temp 19F
3-5 Minute 80F
Forum wont let me add pictures with post until I have more posts. Feel free to see my album with the results.
Well worth it in my opinion!
b3ross is offline
post #17 of 19 Old 01-08-2017, 01:14 PM
09SDLariat's Avatar
Quoted: 39 Post(s)
Garage
Same thing here, truck still starts right up. I don't see the big help that the supplemental cab heater does any difference. I let the truck run for at least 20 minutes before I get in and drive.
New:2016 F-250 XLT,6.7 Diesel, Bone stock,
Work:2016 F-450 XL 6.7 16' Aluminum box. 170,000 mi
Sold: 2009 F-250 Lariat, Bone stock, BFG All Terrains
Sold and Missed: 2003 F-150 2 WD Super Cab, Step side. BF All Terrains. "Grandpa's Truck"
Work:2011 Chevy Express 3500 6.0L, Custom roof rack. Sold
09SDLariat is offline
post #18 of 19 Old 01-09-2017, 12:29 PM
doczenith1's Avatar
Quoted: 17 Post(s)
I did some testing of the supplemental heater when my truck was new. The full set of data is available via the link in my sig including some comparisons with and without using the block heater. In the snip below you can definitely see that the supplemental heater is doing a good job. Ambient temps were 5 degrees F and after just one minute I was getting 54 degree air through the vents.
HeavyAssault and midget like this.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
The Following User Says Thank You to doczenith1 For This Useful Post:
midget (01-09-2017)
post #19 of 19 Old 01-09-2017, 03:13 PM
Azrael15's Avatar
Quoted: 6 Post(s)
I have never timed my truck warming up, but this morning, it was -21F when I cranked up. Truck was plugged in all night, block and oil heaters. I let it run for 15 min, got in and in about 5 min I had warm air blowing. The block heater gets the coolant up to about 40-50 before I crank it, and the oil hits maybe 30-40.
2012 F250 Lariat 4x4 CCSB
Ezlynk w/ GDP tuning 0-150hp
5" Flo Pro
2.5" Leveling
35x12.5x20 Toyo Open Country AT2
Azrael15 is offline
