EGR block off only? - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 15 Old 10-10-2016, 06:04 PM
Quoted: 380 Post(s)
Originally Posted by bogeyman View Post
Thats for that - for some reason, I was under the impression that (for the 2015 model year forwards) the warranty was now only 3yrs/36k.
So, based on your information, as I *now* understand it, the "bumper-to-bumper" warranty is 3yr/36k and that covers just about anything going wrong. After that expires, I'm down to the engine-only (or does that include engine and drivetrain?) warranty that goes for 100k/5yr.
Since I bought this from a non-Ford dealer (used-car), some of my information is incomplete. When I have some time, I shall pop into my local Ford dealer and see if they can fill in some of the blanks.
3yr/36k bumper to bumper
5yr/60k transmission (drivetrain)
5yr/60k safety restraint
5yr/100k engine
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
dlr
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
post #12 of 15 Old 10-11-2016, 04:39 AM
Quoted: 17 Post(s)
Originally Posted by lowmpg View Post
Nope, they don't disable the EGR.
my bad, i assumed since its done with cummins and ecodiesel it would/could be done on 6.7 ford
2017 f-350 cclb 6.7 285-75-18 Toyo a/t
1987 f-350 6.9, 60f/10.25 r, locked 38 tsls, dbl lcks
1978 f-150 37's
2017 F-150 4x4 crew stx 5.0
on truck # 28
Kubotaorange76 is offline
post #13 of 15 Old 10-11-2016, 09:05 AM
Powerjoke11's Avatar
Quoted: 5 Post(s)
Originally Posted by HectorSaenz View Post
I say this as unrudely as possible: I find that hard to believe. Completely removing the EGR without aftermarket tuning (as you stated) without going into Limp Mode and having the dash lit up like a Christmas tree doesn't make sense. I'm sure there's another factor in here that was unmentioned
The truck will have close to 13 dtc codes but the truck wont go into limp mode but as soon as a sensor fails for the dpf the truck will go into idle only and the computer will put the wrench light on the dash. On my 2011 my egr valve failed at 200,000mi so i ripped the egr and the cooler off then drove it for 8 months until the urea pump failed and clogged the dpf from it not being able to go into regen mode. But as soon as the first dpf pressure sensor reached its voltage limit the truck shut off and went into idle only mode.
2011 F-350 srw, d****** with custom ccs tunes (x3,no pilot injection,no preliminary torque managment, vgt off @ idle) Sounds and smokes like a 7.3 but just way faster.
Powerjoke11 is offline
post #14 of 15 Old 10-11-2016, 05:27 PM
Quoted: 2 Post(s)
Urea has nothing to do with regeneration
malinz is offline
post #15 of 15 Old 10-12-2016, 11:49 AM
doczenith1's Avatar
Quoted: 15 Post(s)
Originally Posted by blwnsmoke View Post
So the egr is engine related which is covered for 5yr/100,000 miles.
I believe that the EGR is covered under the 8yr/80,0000 emissions warranty. I have my egr cooler replaced (CEL code P0401) at about 2 weeks after my 5yr warranty ran out.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's - Ordered 10/27/2010; Delivered 12/13/2010
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
