FORScan App - Page 27 - Ford Powerstroke Diesel Forum
 43Likes
post #261 of 282 Old 01-12-2020, 02:11 PM
I'm a greenhorn...anybody know if FORScan can be used with anything more than Ford products? Like GM/Chrysler?
I've got a friend's Dodge that Forscan wont read...
Thanks!
k
Tiny:
2013 F-350 6.7 DRW 4x4 FX4 Lariat Loaded
Deleted Lifted Tonneau'd Goodrich mudders
Unknown tuner/chip
Kilowatt is offline
post #262 of 282 Old 01-12-2020, 03:52 PM
Quoted: 115 Post(s)
Thanks!
k
Ford/Lincoln products only I believe.
The Resurrection
lowmpg is offline
post #263 of 282 Old 01-18-2020, 03:31 AM
Quoted: 17 Post(s)
2011 Lariat Ultimate
Used forscan to set to off the following, did it in basic mode not "as built"
Confirmed working at the moment:
Bambi mode on (it was listed as Europe only)
Welcome screen off, seems it only changed the cluster still have the NAV active ford screen on start up
TPMS since I have used aftermarket wheels from a '17, sensors are not compatible.
Driver belt reminder
Still pending to verify on next drive:
Forced regen/DPF% screen (didn't work on the drive today)
Options that were not there:
Number of flashes on bump
ehagerty is offline
post #264 of 282 Old 01-18-2020, 05:51 AM
Quoted: 105 Post(s)
The number of flashes on the turn signal is there. I have mine set to 5 for a lane change. With a trailer hooked to the 7 pin socket, it adds 2 flashes more for the lane change.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #265 of 282 Old 01-18-2020, 06:32 AM
Quoted: 17 Post(s)
Hummm I wonder what it is under? I didn't see it under SCCM. I was not in "as built" mode just where there are the drop downs. I will look again to see if maybe it is worded differently and I just missed it
ehagerty is offline
post #266 of 282 Old 01-18-2020, 11:55 AM
Quoted: 115 Post(s)
Line 57 of this spreadsheet. It is there.
https://docs.google.com/spreadsheets...#gid=882975515
The Resurrection
lowmpg is offline
post #267 of 282 Old 01-18-2020, 12:12 PM
Quoted: 17 Post(s)
Yes I have that spreadsheet but when I go into Forscan the non-as built part is just drop downs and you just choose enable or disable. I felt safer using it. There is no option to do flashes there for my 2011. I might poke around in as-built but was afraid of screwing something up
ehagerty is offline
post #268 of 282 Old 01-19-2020, 03:39 AM
Quoted: 115 Post(s)
Yeah it isn't going to show up in the drop down, you'll need to edit the cell. There is nothing to it at all.
The Resurrection
lowmpg is offline
post #269 of 282 Old 01-19-2020, 04:06 AM
Quoted: 17 Post(s)
Cool I will try just that one today.
The DPF% screen is a little more sketchy since I have seen conflicting numbers posted. I switched it in the drop down to manual regen on but there is no screen showing % so o way to know to manual regen or its status.
Is this the speed limiter? If so at what speed does it kick in? Is it worth shutting off?
ehagerty is offline
post #270 of 282 Old 01-19-2020, 06:44 AM
Quoted: 115 Post(s)
I've never seen anyone post about modifying 'speed control' so considering what you're playing with, I'd leave that alone if it were me
The Resurrection
lowmpg is offline
