Cruise Control Fuse? - Ford Powerstroke Diesel Forum
post #1 of 3 Unread 01-21-2020, 08:18 AM Thread Starter
Turbo2's Avatar
Quoted: 2 Post(s)
My cruise control stopped working on my 2008 F250 6.4l. I looked through the owners manual but I can't find a fuse or relay even listed.
Turbo2 is offline
post #2 of 3 Unread 01-24-2020, 09:11 PM
Problem will be one of the sensors on the bottom of your master cylinder. They are cheap, basically your cruise thinks the brakes are being applied, so it won't engage. It is independent of the brake light circuit.
Major Problem is offline
The Following User Says Thank You to Major Problem For This Useful Post:
Turbo2 (01-27-2020)
post #3 of 3 Unread 01-25-2020, 09:35 PM
Quoted: 24 Post(s)
Your cruise control will not work if you have a CEL pending or on. May want to check with a scanner for a CEL pending
colesalisbury01 is offline
The Following User Says Thank You to colesalisbury01 For This Useful Post:
Turbo2 (01-27-2020)
