2008 transmission flush? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-22-2019, 05:29 PM Thread Starter
Hello Ford guys
I have an 08 F-350 I bought used & is my 1st diesel. Iíve seen & heard that the transmission flush can be harmful if it hasnít been done before on older & higher mileage trucks. I only want whatís best for my truck so not sure about what to do. It has 175,000 & as far as I know has never been flushed or even the fluid changed. Insights?
Thanks
stiggers is offline
post #2 of 3 Old 11-22-2019, 05:47 PM
ZMANN's Avatar
Quoted: 3955 Post(s)
so your choices do nothing or do a pan drop , filter, refill or a couple of times or a flush
your 08 may have the bell housing filter so figure that out
and a real ford Rotunda flush just replaces dirty fluid for hot fresh fluid quart for quart
so if fresh fluid is going to doom your tranny it won't be the flush it will be the bad maintenance
if i were you i would look at the fluid and see what shape it is in and decide from there , a replacement tranny is about 4k from ford
6.0 flush pdf
ZMANN is online now
post #3 of 3 Old 11-23-2019, 03:12 PM Thread Starter
Thank you for the advice & information.
stiggers is offline
