2010 6.4 problems - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-11-2019, 02:15 PM Thread Starter
2010 6.4 problems
Okay so I bought the truck with 112,000 miles on it. Ran fine nothing wrong. I got the dpf deleted and a sct tuner x3 I believe. Couple months go by and it would hard shift and stay at high rpm until I got home. I would plug the tuner in and reset it back into the same custom tune I had it in and it would run perfect. A week or month would go by and again it would do it again had dshift then stay high rpm all the way home. This time it would not crank. I had to unplug a wire my local mechanic told me and touch it to the positive of the battery and it would fire up and run. I would reset tune and truck runs perfectly. We I got smart and found a pattern there is a specific sharp turn that I have to brake then accelerate coming out of turn in my town. It hard shifts and stays in what feels like a low gear when I accelerate after braking. I plugged tuner up and it gave a brake circuit b code. Today I got in it and the truck would not even crank. Left nothing on all night. What can be causing this? Tuner need updating? It has to be electrical, sensor, breaker? Nothing should be wrong with hard components. Something is not getting a good signal or a wire is short circuiting. But it all started after I got the dpf deleted and the tuner. On I need to mention that. Brand new tuner didn’t come in the day the mechanic did work so I’m the one I have is the old sct x3 he got out of his employees truck and used.... please help I need a reliable truck.
Strick1228 is offline
