Gauge cluster to add to truck - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-15-2019, 10:47 AM
ChrisSki's Avatar
Quoted: 506 Post(s)
I have a 6.0 and prefer the Edge CTS monitor. It displays 10 gauges and if the truck has a sensor, I can switch in between whichever 10 I want. It can be pricey to add an external sensor in. Adding a oil pressure gauge, I have to buy their sensor, and EAS attachment. I think around $200. When tired, I like using the grab assist handle on the A Pillar. I also like being able to change one of those 10 gauges to something else easily.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #2 of 11 Old 05-15-2019, 11:26 AM
Heavy_GD's Avatar
Quoted: 3044 Post(s)
Garage
Feedback Score: 3 reviews
@[email protected]
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
The Following User Says Thank You to Heavy_GD For This Useful Post:
[email protected] (05-15-2019)
post #3 of 11 Old 05-15-2019, 12:45 PM Thread Starter
zell66's Avatar
Quoted: 27 Post(s)
for what I can research EGT is a must, but I see also boost is a big one. If I have a factory boost gauge do I need a aftermarket one?
zell66 is online now
post #4 of 11 Old 05-15-2019, 01:12 PM
RandomForumGuy's Avatar
Quoted: 201 Post(s)
Garage
Most go with a screen type monitor opposed to a pillar style 3 gauge setup. Its easier and you can change what you want to monitor. Coolant temp, oil temp, trans temp, and egt are the big 4 to watch. The factory boost gauge is accurate and you dont need an aftermarket one. A warning light will come on if oil pressure drops below 5 psi and there is rarely an oil pressure problem on these trucks
RandomForumGuy is offline
post #5 of 11 Old 05-15-2019, 01:40 PM
Corey@CNCFAB's Avatar
Quoted: 1355 Post(s)
Feedback Score: 4 reviews
Right now we have a special going on with EDGE and if you buy the Insight CTS2 monitor, they have a rebate for a free accessory. Which in your case you could get the EGT probe.
https://cncfab.us/i-30497709-edge-pr...cle-84130.html
www.cncfab.us
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #6 of 11 Old 05-15-2019, 02:47 PM
Lipka101's Avatar
Quoted: 164 Post(s)
I have a Factory transmission temperature, boost, engine temperature and fuel gauge, thinking of adding a 3 pod on my A-piller. What should I have there to help watch engine and other parts while towing?
Was thinking of adding:
Oil pressure gauge
Oil temperature Gauge
Transmission temperature gauge (for a more accurate reading with digital)
or should I used a different combination?
My truck is a 2008 F-350 Crew Cab SRW, not deleted (due to warranty I will not delete until sometime in the future)
Just skip the pillar gauges and buy an edge insight cts2. You can see all of those plus many more and read/clear codes.
Sent from my iPhone using Tapatalk Pro
2008 f250 ccsb kingranch
Sct Livewire with Gearhead custom tunes. Edge insight cts.
Mbrp dpf/cat delete. PMF stage 2 traction bars.
Drp egr delete w/wastegate. LP batmowheel, 22x9.5 fuel hostage with nitto terra grappler. 12.9 sec. 1/4 mile at 104.5 mph
Lipka101 is offline
post #7 of 11 Old 05-15-2019, 02:49 PM
Lipka101's Avatar
Quoted: 164 Post(s)
www.cncfab.us
Egt probe is not necessary on the 6.4 as it already has one in the up pipe that is more reliable than the edge.
Lipka101 is offline
post #8 of 11 Old 05-16-2019, 03:17 AM
I wasn't sure if he wanted one in the exhaust manifold. I assumed he already knew his truck had one.
But EDGE's rebate is for any EAS accessory with the purchase of the Insight CTS2.
www.cncfab.us
post #9 of 11 Old 05-16-2019, 04:37 AM Thread Starter
zell66's Avatar
Quoted: 27 Post(s)
is this one I can tie into?
Thank you for the suggestions but I already have most of the gauge pods and a-piller pod case, so this is the direction i am going in.
post #10 of 11 Old 05-16-2019, 04:43 AM
Lipka101's Avatar
Quoted: 164 Post(s)
Doubt it.
Lipka101 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
No crank, gauge cluster flutters kclough 99-03 7.3L Powerstroke Problems 25 02-23-2019 09:23 AM
CLUSTER QUESTION texasstroker 6.4 Powerstroke Interior Discussion 4 01-14-2019 08:47 PM
Good Truck gone Bad?!? Substantial Drivability Issues aggiediesel01 94-98 7.3L General Powerstroke Discussion 13 02-17-2017 10:14 AM
How much can I sell my truck for? Brydawg512 99-03 7.3L General Discussion 30 10-26-2016 04:52 PM
The reason I'm sore over my 6.0 Diesel KYSkipper 6.0 Motor problems 45 12-12-2006 01:58 PM
