1st Diesel... untouched 2010 F350 auto - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-19-2019, 09:30 AM Thread Starter
Cool 1st Diesel... untouched 2010 F350 auto
Good Morning everyone,
Just bought a=
2010 F350 6.4 Diesel, auto, 250KM supercab, shortbox, gov't maintained, very tight train
Runs good, checked oil, way over full?? DPF??
Is it really that important to remove the EGR + DPF?
Could removal screw up engine?
Total cost for do it selfer?
OR, what people are paying to have both removed + where work done.
I'm looking to remove these items in a few mos.
Be nice to get help on here, in turn I will post info I gain during the removal procedure
and anything else I change.
Thanks,
Dufferin
dufferin is offline
post #2 of 5 Old 04-19-2019, 02:35 PM
Quoted: 192 Post(s)
Over full on oil is from fuel leak down in the cylinders during Regen. That's why you need to remove those components.
SOOTIE is online now
post #3 of 5 Old 04-19-2019, 05:12 PM
RandomForumGuy's Avatar
Quoted: 201 Post(s)
Garage
Removing emissions is key if you want to have your truck last. I wouldnt worry about the oil until you change it yourself and verify it was at the correct level when you started.
No shop will remove your emissions above the table as its illegal. For the cheapest option look here : https://www.google.com/amp/s/www.rpi...f-delete-tuner
You will need to buy or modify the exhaust yourself
RandomForumGuy is offline
post #4 of 5 Old 04-20-2019, 07:06 AM Thread Starter
Thanks, Sootie + RandomForumGuy,
Anybody tried gutting dpf, then weld it back up?
Or, remove cat+dpf, replace with sensor attached (via welded nut) straight pipe?
Is the cat that restrictive? OK to leave it in there?
dufferin is offline
post #5 of 5 Old 04-20-2019, 07:51 AM
Quoted: 201 Post(s)
Garage
People have gutted the dpf and cat with success. You will need a tuner to make the truck run right. You can leave the cat in but i wouldnt see why you would.
Sensors can be put back in place or removed. They will be shut off completely with the install of a tuner.
Similar Threads
Thread Thread Starter Forum Replies Last Post
2006 F350 6.0 low miles untouched, no power mudkaiser 6.0L Performance Parts Discussion 19 07-19-2018 03:26 PM
Houston DHRA / HAPS ALL Diesel Show 'n' Shine racingwebster South Central 23 10-14-2006 03:12 AM
schematics diagramming anyone ? 2000 F350 Diesel chrishovar 99-03 7.3L General Discussion 0 09-29-2006 04:48 PM
Amsoil's new Diesel Oil 5W-40!! Diesel Nut Vendor Jungle 0 09-29-2006 02:51 PM
