New CA smog laws???? - Page 12 - Ford Powerstroke Diesel Forum
 114Likes
post #111 of 152 Old 02-20-2017, 05:41 PM
Quoted: 133 Post(s)
Originally Posted by Fox Hunt View Post
If I run it on a stock tune it's going to throw a code for insufficient flow I would imagine since I have an egr delete
Sent from my iPhone using Tapatalk
Yup. Only real options is to see if some way to trick the ait2 sensor to prevent an EGR low flow CEL or reinstall and EGR cooler.
Rossterman is online now
post #112 of 152 Old 02-20-2017, 05:54 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
That is true with the 2006 model truck. The insufficient flow will throw a wrench light. You have two options:
(1) Install a BPD EGR cooler
(2) Register your truck in a county that's not in smog program.
Your up North there has to be a county to the east of you that doesn't participate in the smog program. Look up the DMV website and check your area. I reside in the Elk Grove area but am living in the mountains according to my drivers license. Truck of coarse lives with me lol. The majority of the state as far as square miles is not involved with the smog program. If you have friends or family out of smog counties move your registration there.
Look over the map online. May be easier than you think.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3” CAC Pipes & CSF 7106 I.C.
4” Diamond Eye SS Exh System
W/two 4” SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #113 of 152 Old 02-20-2017, 05:56 PM
Fox Hunt's Avatar
Quoted: 31 Post(s)
Well I turned it back to stock and by time I got home tonight the P1000 code was gone. So from my understanding, all the readiness checks are complete and I have no other codes. I guess I'll have to run it back by before it throws a lack of flow code lol
Fox Hunt is offline
post #114 of 152 Old 02-20-2017, 06:03 PM
Fummins Mod
junior125's Avatar
Quoted: 2187 Post(s)
Garage
have a custom tune written that is basically a stock file with EGR turned off
Mike
2005 CCSB F250 4X4
P-Pump 12 Valve/NV4500
Originally Posted by Mike in Cornville View Post
When a saint tells you, ya gotta listen.
junior125 is offline
post #115 of 152 Old 02-20-2017, 06:09 PM
Fox Hunt's Avatar
Quoted: 31 Post(s)
That's what I had when I had the test done
Fox Hunt is offline
post #116 of 152 Old 02-20-2017, 06:11 PM
Fummins Mod
junior125's Avatar
Garage
as long as it was done right you should have no issues getting smoged
Mike
2005 CCSB F250 4X4
post #117 of 152 Old 02-20-2017, 06:41 PM
Fox Hunt's Avatar
Quoted: 31 Post(s)
Well he some how can check the egr and see that it hasn't completed its system check, and with the egr turned off in the tune I'm not sure it ever will complete it
Fox Hunt is offline
post #118 of 152 Old 02-20-2017, 07:29 PM
Durapig Eater's Avatar
Quoted: 163 Post(s)
Move out to Ohio, no emissions testing here whatsoever. Our state just dumps salt all over every drivable surface so by the time you get your vehicle paid off its rusting apart....
We also still have our guns and good old lead ammo to keep the Libtards at bay.
Durapig Eater is offline
post #119 of 152 Old 02-20-2017, 07:34 PM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 599 Post(s)
Minnesota is another option...
Cost of living is 10x lower and even for a libtard state, we still have our rights....
2015 F350 SRW CCSB Lariat - Stock, for now
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, Egr delete with BD intake elbow, SCT X4 with tunes from Tyrant Diesel, Monitored by CTS, Fox 2.0s. - SOLD
-Matthew
CrazyS0b is offline
post #120 of 152 Old 02-21-2017, 05:43 AM
PowerSmoke07's Avatar
Quoted: 45 Post(s)
Garage
A lot of these shops are getting smart too. A few years ago when I smogged it was still just the visual inspection, the jack wagon tried to fail me for my bypass oil and coolant filters because they weren't "factory" and I had to repeatedly explain to him that there is nothing that says I can't install extra filtration, especially considering they have absolutely nothing to do with the emissions system...except that I won't have to replace a ruptured EGR cooler because it got plugged up. Last time I smogged was in November and was the first I knew of them hooking up the computer. During the snap test there was a fair cloud of soot under the truck (downpipe into the cat, then only about 3" of pipe behind the cat) and he was looking in the mirrors for the smoke. When he was done he waved me over and said "nice trick having nothing behind the catalytic converter to let me see the smoke, bet it makes it easy to swap out your straight pipe" "whatever do you mean?" "You're not as sly as you think, I can see where the clear coat is stained on your fender, just like I bet that is just a polished 'stock' turbocharger under there isn't it" "of course" "your truck passes because I can't fail you based on speculation of how you run it when it isn't smog day, but just know, there are some jerks that would fail you instantly for that aftermarket turbo since Garrett does not have an CARB E.O. number for the Powermax" "I'll be seeing you next time"
I love the state of CA, amazing scenery, so much to do, but can't stand the STATE of CA. Unfortunately being military, I don't have a choice for a while...or maybe I do. If these clowns actually follow through with seceding, then we're gone, they can't actually be stupid enough to think that the government is going to keep military here when CA clearly wants nothing to do with the U.S. They'll be left high and dry, no military, no gun owner is gonna wanna stay so there goes any thought of a militia, they'll be screwed...When do I start packing? Lol
PowerSmoke07 is offline
