New CA smog laws???? - Page 11 - Ford Powerstroke Diesel Forum
 114Likes
post #101 of 152 Old 02-20-2017, 09:50 AM
Fox Hunt's Avatar
Quoted: 31 Post(s)
Got mine smogged today with an unlimited tow tune on, no p1000 codes or anything on my cts, but the egr readiness was coming up on his end and he failed me. He didn't even look under the truck or notice I have an egr delete. Anyone got any ideas if this readiness will go away with driving it even though the egr is turned off? Is it possible to turn the egr on and allow it to function but hide the code from lack of flow?
Sent from my iPhone using Tapatalk
Fox Hunt is offline
post #102 of 152 Old 02-20-2017, 09:54 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 596 Post(s)
Feedback Score: 11 reviews
Plug your egr valve back in.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
C-A-P-S CAPS! CAPS! CAPS!
powerstrokeshellback is offline
post #103 of 152 Old 02-20-2017, 10:12 AM
Fox Hunt's Avatar
Quoted: 31 Post(s)
Already was plugged in
Fox Hunt is offline
post #104 of 152 Old 02-20-2017, 10:27 AM
BBBRRRRRTTTTT
Quoted: 596 Post(s)
had you just recently switched tunes or anything?
post #105 of 152 Old 02-20-2017, 10:38 AM
Fox Hunt's Avatar
Quoted: 31 Post(s)
Yes, which is what the problem is I'm hoping. I was a couple days ago, and I haven't drove the truck much. What I'm curious about though is if that egr readiness will even go away after I drive it for while since the tune turns it off anyways. Guess I can drive it awhile and retry. If that doesn't work I'm gonna have to throw an egr cooler on....
Fox Hunt is offline
post #106 of 152 Old 02-20-2017, 10:56 AM
Quoted: 12 Post(s)
Most likely a side effect of the tune. Most of the "custom tunes" have the egr valve off function active, which may not allow the readiness monitors to go through.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #107 of 152 Old 02-20-2017, 11:09 AM
cbramsey5898's Avatar
Quoted: 6 Post(s)
Garage
Makes me so glad to have moved out of the People's Republik of California 20 years ago. The smog tests were a pain even then. I can imagine that things haven't improved.
cbramsey5898 is offline
post #108 of 152 Old 02-20-2017, 11:29 AM
Quoted: 133 Post(s)
Reflash back to stock and drive it for a few hundred miles and you should be good for a retest. You need to run if for some time before the computer will confirm that there has been enough data collected to allow smog testing to be performed after confirming all onboard systems are working properly. Most tuners cause the egr to remain closed and not set a check engine light. Most likely the smog machine was able to determine it was defeated hence the fail.
Now, since you have the egr blocked or deleted you are in for some problems as the obd2 system will throw a ait2 CEL forEGR insufficient flow since the sensor wont detect a rise in the intake temp that it should of the valve was flowing hot exhaust gasses with a properly functioning EGR.
Not sure of the logic (temp diff requirement) between ait1 & ait2. Some people used to fool pre and post cat O2 sensors by adding a resistor to change to value of the post cat sensor. In your case it's probably best to install a BPD EGR cooler and be done with it but maybe someone has some insight as to how to address the ait2 sensor issue you will have.
john galt likes this.
Rossterman is offline
post #109 of 152 Old 02-20-2017, 11:32 AM
Fox Hunt's Avatar
Quoted: 31 Post(s)
If I run it on a stock tune it's going to throw a code for insufficient flow I would imagine since I have an egr delete
Fox Hunt is offline
post #110 of 152 Old 02-20-2017, 04:24 PM
G8orFord's Avatar
Quoted: 2517 Post(s)
Garage
I don't think you'll ever get rid of the readiness code with a delete. There may be a tuner out there that can do it, but I don't know of one. Time to reinstall the EGR or move.
Patriot and john galt like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
