best calipers - Page 3 - Ford Powerstroke Diesel Forum
 2Likes
post #21 of 24 Old 03-09-2016, 09:08 AM
Bump To Pass!!
toren302's Avatar
Quoted: 2586 Post(s)
Originally Posted by smokersteve View Post
Also upgrade to dot 4 brake fluid.
Um...this is horrible advice for most American vehicle platforms.....Dot4 (usually a synthetic fluid) can and will foam under ABS panic conditions resulting in LOSS of all braking capability's. It also will eat away at the seals in the system. There is a reason DOT 3 is specified and required in these. Be EXTREMELY careful with which fluid you are using and make sure it is compatible with the system it is being put in.
toren302 is offline
post #22 of 24 Old 03-09-2016, 10:45 AM
Quoted: 332 Post(s)
Not sure if this applies to all of the 6.0 model years, but mine says to use DOT 3. I've been using, for years, Valvoline Dot 3/4 fluid with no issues. This allows me to use the same brake fluid in all my vehicles.
2017 F350 DRW King Ranch FX4
Blue Jeans w/Caribou Accent
No mods...yet. Enjoying stock and full warranty!
2004 F350 6.0 - Traded 2/4/17 (Pity the fool who bought it)
jd4010 is offline
post #23 of 24 Old 03-09-2016, 03:06 PM
Mitch
thebierguy's Avatar
Quoted: 110 Post(s)
Interesting on the brake master cylinder. I will have to watch mine. Had a left rear stuck this past summer, replaced with a NAPA reman. It stuck again a few weeks ago. I greased it up with the Permatex purple as the slides seemed alittle dry (not rusty). Seems better now. Time for an all around brake job though!.
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #24 of 24 Old 03-09-2016, 03:20 PM
smokersteve's Avatar
Quoted: 21 Post(s)
Same here. I have been using dot 3/4 valvoline since 40,000 miles.
smokersteve is offline
