6.0 EBP KOEO - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 16 Old 12-29-2013, 08:45 AM Thread Starter
FJuanfiddy mod
Dave's Avatar
Quoted: 12 Post(s)
I can solve the 3 dot issue.
Pull your sensor, Clean it, replace the EBP tube
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #12 of 16 Old 12-29-2013, 09:22 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 21 Post(s)
My 04 reads EBP but I don't know the difference with KOEO. Never paid attention.
dhanna6powerstroke is offline
post #13 of 16 Old 12-29-2013, 09:47 AM
Quoted: 28 Post(s)
Those three dots are key on engine off. I had tapped the screen to turn the cts on... With th engine running it displays proper ebp
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #14 of 16 Old 12-29-2013, 10:56 AM
Quoted: 9 Post(s)
Originally Posted by Dave View Post
No the livewires problem was in the programming. THeir equation was wrong. Just like it was wrong for EGTs initially
Think I figured it out. Their calculation is in kPA, labelled/assigned as inHG. You would have to manually convert from kPA to inHG/PSI/etc... The internal conversion using the Livewire would be incorrect because their value (in kPA) is reported in inHG. Anyway, why can't SCT just fix it?
Sent from AutoGuide.com App
- Scott -
2004 F-350 Lariat CC DRW
New Blackwater Engines Long Block @ 126,000 miles
w/ ARP Head Studs and OEM Gaskets
EGR Delete
Straight 4" Exhaust, Turbo Back
Blue Spring Upgrade
s20055 is offline
post #15 of 16 Old 12-29-2013, 02:48 PM
Quoted: 3 Post(s)
To do what you want to do you need something like AE or IDS and anything else that might show the pids. SCT data software might but I haven't looked yet. Anyways this is what EBP actual vs MAP vs Baro and also EBP Volts vs EBP actual vs EBP desired. This was taken from AE tonight.
EDIT: sorry but I must have changed a pid when getting the screen shot so EBP desired is not there but that value is a 0
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #16 of 16 Old 12-29-2013, 03:10 PM
Quoted: 9 Post(s)
I saw those PIDs on the Livelink Software. SCT needs to make some updates to the Livewire Firmware so these PIDs will display correctly. Seems like it should be an easy fix.
- Scott -
EGR Delete
Blue Spring Upgrade
s20055 is offline
